gsr stops at 7 rpms
Old Feb 2, 2004 | 05:35 PM
jxj220z28's Avatar
Default gsr stops at 7 rpms
Does anyone know why a 98 gsr would not go past about 7200 rpms?
Old Feb 2, 2004 | 05:38 PM
LSTEG96's Avatar
Default Re: gsr stops at 7 rpms (jxj220z28)
did u just buy the car? is it an ls????
Old Feb 2, 2004 | 05:40 PM
D@nnY's Avatar
Distributor or cam timing..
Old Feb 2, 2004 | 05:45 PM
LSTEG96's Avatar
Default Re: gsr stops at 7 rpms (GSRT37)
5 bucks says this guy got OWNED and bought an ls thinkin it was a gsr!!!
Old Feb 2, 2004 | 05:48 PM
jxj220z28's Avatar
Default Re: gsr stops at 7 rpms (LSTEG96)
no its a gsr
Old Feb 2, 2004 | 05:52 PM
LSTEG96's Avatar
how sure are u of that?
Old Feb 2, 2004 | 05:53 PM
jxj220z28's Avatar
100% positive its a gsr
Old Feb 2, 2004 | 07:34 PM
daNk9's Avatar
just tune it up
Old Feb 2, 2004 | 07:36 PM
Kendall's Avatar
Is VTEC engaging? if not, then it's probably a problem with oil pressure.
Old Feb 2, 2004 | 07:43 PM
gstyper's Avatar
Default Re: (Kendall)
check engine light?
Old Feb 2, 2004 | 08:33 PM
AspectIndustries's Avatar
Default Re: (gstyper)
You need to give us more info then just that. Let us know strange occurance? Shaking? etc..etc.. Any more info will help then just that. -
Maybe he got an LS ECU? Who knows.
-=P
Old Feb 2, 2004 | 08:34 PM
lke2drvgsr's Avatar
Default Re: (synik)
either got owned by buying an LS or got owned by buying a gsr with ls ecu
Old Feb 3, 2004 | 08:58 AM
jxj220z28's Avatar
Default Re: (lke2drvgsr)
its definetly a gsr i bought it from an acura dealership it only has a cold air on it
when the rpms get to 7200 it just bucks a little and doesn't go past that
Old Feb 3, 2004 | 09:30 AM
Default Re: (jxj220z28)
Whats worse to worse. Is bring it back to Acura and tell them the SUCKS *****. Its not running correctly. Let them solve it. -
Old Feb 3, 2004 | 10:27 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jxj220z28 &raquo;</TD></TR><TR><TD CLASS="quote">its definetly a gsr i bought it from an acura dealership it only has a cold air on it
when the rpms get to 7200 it just bucks a little and doesn't go past that</TD></TR></TABLE>
That's exactly where the B18B ECU cuts fuel for the rev limiter. The valve cover says VTEC and everything on it right? Can you hear the secondary runners opening just before 6000? I would take off the right passenger side kick panel and make sure the ECU says P72 on it.
Old Feb 3, 2004 | 10:32 AM
SHystrdyGSRtdy's Avatar
Default Re: (PatrickGSR94)
on my prelude it runs in limp mode when the car isnt' fully warmed up and you run it hard (prevents from hitting redline and bucks just like you said)
also...when i was installing a front upper strut bar on my prelude a long time ago, i managed to strip a wire out of the socket, i took it to the dealership and they tried to fix it but didn't know exactly what the problem was. they hooked it up to diagnostics and everything was working fine (vtec was supposedly engaging, even though i felt otherwise). so maybe a wire isn't connected or your car isn't warmed up...beats me...clogged cat?? good luck
Devlins 91LS's Avatar
is it warmed up?
AEMintegra22
Jun 24, 2006 09:42 PM
Dramon
Apr 7, 2003 01:02 AM
B_CRUZ!
Jun 6, 2002 03:30 AM
KLN
Mar 11, 2002 09:52 PM
