Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Radiator Coolant
Old Feb 2, 2004 | 04:23 PM
davidnyc's Avatar
Default Radiator Coolant
I will be going to VIR this Feb and was thinking that the temps may be too low for straight water. Is it illegal to run coolant on the track? At worst case scenario, I can run coolant for the trip down and then drain and replace with water at the track.
Old Feb 2, 2004 | 04:30 PM
Chris's Avatar
Default Re: Radiator Coolant (davidnyc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davidnyc &raquo;</TD></TR><TR><TD CLASS="quote"> Is it illegal to run coolant on the track? </TD></TR></TABLE>
All the HPDE I ever attended, nothing was ever said.
I think only racing sanctioning bodies regulate that.
Old Feb 2, 2004 | 04:31 PM
Back in Black's Avatar
Rather OG
Not illegal, although I have my own thoughts on the matter
You better be doing the sprint race, David!
Old Feb 2, 2004 | 04:32 PM
Willard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davidnyc &raquo;</TD></TR><TR><TD CLASS="quote">Is it illegal to run coolant on the track?</TD></TR></TABLE>not illegal... but under race conditions pure water is desirable.
what if you mixed it thin? 20%80%?
Old Feb 2, 2004 | 05:13 PM
bus stop's Avatar
Default Re: Radiator Coolant (Jason Franza)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jason Franza &raquo;</TD></TR><TR><TD CLASS="quote">You better be doing the sprint race, David!</TD></TR></TABLE>
David, David....are you home?
Old Feb 2, 2004 | 06:23 PM
DBurke's Avatar
Default Re: Radiator Coolant (WhosITR)
I use the Valvoline Racing Super Coolant. Its mixed with distilled. I like it better than Water Wetter simply because it does have a hint of a glycol scent to it. I like this because it will alert you to any little leaks that may pop up. Its purple too, you'll get extra internal bling points for that.
On a side note. I'd highly recommend trying the new Valvoline Race Oils. If you run w/o a cat. There is additonal sulfur content in the oil that could prematurely kill the cat. My oil temp guage is lower, I can't say how much but I used to run at 210 and now I'm halfway between 180 and 210 (the only marks with numbers before 270).
All available at NAPA.
Old Feb 2, 2004 | 07:00 PM
davidnyc's Avatar
I am feeling the sprint race... I'll pray about it tonight and we'll see if I do it.
My main concern about the coolant is that on a warm day up here it is 30 degrees. So, I'll just add a little coolant for the trip to Va and drain when I get down there.
Old Feb 2, 2004 | 07:12 PM
davidnyc's Avatar
Just prayed. Done. We'll have fun
Old Feb 3, 2004 | 01:39 AM
kedwards's Avatar
From page 132 of the CCR http://www.nasaproracing.com/rules/ccr.pdf
"The radiator should not have antifreeze/coolant."
From the Race Car Technical Inspection Form http://www.nasaproracing.com/i...h.pdf
there is a checkoff for "no coolant present". I take that to mean antifreeze.
Hope this helps.
Keith, who has seen some freezing temperatures at VIR in February...
Old Feb 3, 2004 | 02:13 AM
jlucas's Avatar
Default Re: Radiator Coolant (kedwards)
NASA's normal policy is no coolant but for races when there is chance of freezing they usually post an exception. For example, they did this for the 25 hour.
Jeremy Lucas
Team Honda Research
Kumho-Cobalt-Comptech
Old Feb 3, 2004 | 03:12 PM
Rather OG
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davidnyc &raquo;</TD></TR><TR><TD CLASS="quote">Just prayed. Done. We'll have fun </TD></TR></TABLE>
Nice!
Old Feb 4, 2004 | 04:10 AM
117's Avatar
117
What about Evans coolant? Would this also be illegal for NASA or SCCA events?
vroomboom
Honda Civic (2001 - 2005)
May 22, 2008 04:44 AM
invisible
Mar 20, 2007 07:43 PM
NA_H22_Ej
Jun 17, 2006 10:24 PM
acuracy r
May 20, 2005 08:33 AM
DelSlowdier
Jan 16, 2005 08:42 PM
