B18B whit ctr piston
Hello, i'm new in this forum. I'm from canada and I speak french, so sorry for my english
I want to know if ctr piston clear in a b18b block. I know that they fit in the engine, but I don't know if it's safe.
thanks
don't tell my to us search, it's already done.
tanks
.I want to know if ctr piston clear in a b18b block. I know that they fit in the engine, but I don't know if it's safe.
thanks
tanks
In order to fit the ctr pistons onto the ls rods, you need to either shave down the rods or enlarge the pistons bosses. Other than that, it should be fine, you'll love the low end torque.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fox297 »</TD></TR><TR><TD CLASS="quote">In order to fit the ctr pistons onto the ls rods, you need to either shave down the rods or enlarge the pistons bosses. Other than that, it should be fine, you'll love the low end torque.</TD></TR></TABLE>
I'm sorry, can I ask you to elaborate just a little bit more, I'm just a little slow on the terminology.
-PHiZ
-PHiZ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe »</TD></TR><TR><TD CLASS="quote">The rods will not fit inside the pistons. You have to narrow the small end of the rods, or enlarge the pistons where the rods go.</TD></TR></TABLE>
Is one way safer than the other for high rpm work?
Yeah, its actually about ~1mm on each side of the small end of the rod to make it fit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stock@$$GSR »</TD></TR><TR><TD CLASS="quote">
Is one way safer than the other for high rpm work?</TD></TR></TABLE>
no, no one which way is safer, but the only way to make it work is the method stated above.
-sander
-sander
running that setup in my car right now with a gsr head and 2 layer head gasket
runns fine but you probably will need to run a higer octane or get some 320cc injectors and get it tuned
I see, it is the outside of the rod, I was worried about hte size of the "wristpins" being different, thanks.
-PHiZ
-PHiZ
all_out_jdm
Apr 30, 2005 03:55 PM
