Grind from 2nd to 3rd gear in 92 gsr tranny????
I grind from 2nd to 3rd gear when my rpms are high. Is ther a way to fix this without ripping my tranny apart to replace parts. does any one else have this problem???
I had a slight grind in my ys1 at high rpms is 3rd gear. Its a typical problem with honda trannies. What i did was bought gm syncromesh friction modified transmission fluid (availible at gm dealer) and changed my fluid with this. Its been 15,000 miles and no more grinds. Alot of honda owners have used this and rave about it. It should take the grind away or make it less noticable.
-steve
-steve
whoa, you changed the fluid and your grind stopped???? my old 95 gsr tranny had a grind from 2nd to 3rd gear and i just bought a whole new tranny from a 98 gsr. was your grind real bad like all the time or just when you pushed it passed like 4500 rpm's???? im gonna try that on my tranny.
It's definately the synchros. B series transmissions (especially older ones) are notorious for wearing out synchros. Depending upon how bad it is, Synchromesh may or may not help you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XtremeCarTuner »</TD></TR><TR><TD CLASS="quote">w00t w00t Gm Synchromesh w/ friction modifyer
The Synchromesh Friction Modified isn't recommended unless you're equipped with an LSD. The regular Synchromesh should do fine.
</TD></TR></TABLE>The Synchromesh Friction Modified isn't recommended unless you're equipped with an LSD. The regular Synchromesh should do fine.
Rpizzle
Apr 11, 2005 03:24 PM
RTW DC2R
Sep 14, 2003 06:02 AM
