will this work? or am i asking for trouble
Old Feb 2, 2004 | 11:55 AM
phantom_sol's Avatar
Default will this work? or am i asking for trouble
i was thinking of doing this:
b16a3 head with:
skunk 2 intake manifold
skunk 2 stage 2 cams
skunk valves/ (skunk or crower valve springs)
pct or cp pistons in b18c1 block
stock rods and crank
310cc fuel injectors
190 lph fuel pump
we get 91-94 octane in this area at pump, but i was wondering what compression that might yield and or what power i might expect. does anyone have any recomendations as far as valve springs go? i just read that crower uses eibach and that the eibach springs were good. cp pistons i am unsure of which to get. i want ot hover around the 11.5-12 cr area but how will adding a b16 head to a gsr block affect the gsr's stock compression? will it lower? i used that c-speed racing site to calculate the estimated compression, but it just doesnt seem right. any input would be greatly appreciated
Old Feb 2, 2004 | 12:33 PM
DOHCtorTHRUST's Avatar
Default Re: will this work? or am i asking for trouble (phantom_sol)
if you use the b16 head then it will lower the C/R just a bit... the b16a head dont have the welded chambers like the gsr head does... i dont see why it wont work with this setup... there are guys running 12.5 cr on 91octane...
Old Feb 2, 2004 | 01:38 PM
00 FBP ItR's Avatar
Go w/ CP pistons.
you can run up to 12.5 CR w/ 93/94 octane.
Hit me up if you need the CP pistons.
Old Feb 2, 2004 | 05:02 PM
i was really considering the cp pistons but then i didnt knwo which to get. they have applications for b16 b18 and b18c5 -_-; i was just getting confused being that my engine already is mix and matched. is it possible to weld the chambers? or is that mroe trouble than its worth. should i just see if i can get a minor p&p and or mill it down a bit?
also whats the advantage to oversized valves over stock spec
Old Feb 2, 2004 | 07:31 PM
also, would it be alright to keep my stock rods?
what compression will i be looking at and what rough crank horsepower migh i experience?
Old Feb 3, 2004 | 01:14 AM
jdmDXrex's Avatar
Default Re: (phantom_sol)
on pump gas i wouldnt go higher than 12.5:1 but at that compression i would recommend Port and Polish.
ctr pistons will yield like ~12:1 with b16a but forged pistons will handle the heat better.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phantom_sol &raquo;</TD></TR><TR><TD CLASS="quote">what compression will i be looking at and what rough crank horsepower migh i experience?</TD></TR></TABLE>
you have to decide on a compression first.....
Old Feb 3, 2004 | 03:22 AM
well, i was having a hard time because if i put 11.5:1 compression pistons in the gsr block, then use the b16 head, compressino will be lower than what i would expect. but by how much...
Old Feb 3, 2004 | 10:49 AM
jdmDXrex's Avatar
if you havent bought the pistons yet then just buy ones that make the compression you want.... its not that hard........
b16 head drops compression by 0.2:1.....
Old Feb 3, 2004 | 12:20 PM
Default Re: (jdmDXrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmDXrex &raquo;</TD></TR><TR><TD CLASS="quote">if you havent bought the pistons yet then just buy ones that make the compression you want.... its not that hard........
b16 head drops compression by 0.2:1.....</TD></TR></TABLE>
thanks for the info
sorry i hadnt known the cr drop. so now that helped me a lot
Old Feb 3, 2004 | 01:25 PM
ALLMOTA_EF's Avatar
cp is the bomb SH*T go with cp
GuiVtec
16
Aug 16, 2010 04:20 PM
geekuskahn6
Aug 6, 2009 08:17 PM
ricebowl
Jan 4, 2005 12:13 PM
ricebowl
Nov 13, 2004 10:06 AM
Eyes Only
Sep 15, 2003 05:55 PM
