doees the aem fuel rail do anything?
for your application you probably wont need one, and by probably i mean definitely. i guess there would be the bling factor but save your money.
just read your actual post, your friend is right.
I'd only upgrade the fuel rail if I couldn't get enough fuel after upgrading both the pump, and the injectors. It's likely that I'll never reach that point and neither will you. Don't waste your money.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr98teg »</TD></TR><TR><TD CLASS="quote">i m gonna put it towards a vafc
Just plan on having it dyno-tuned, otherwise you should consider a different upgrade.
</TD></TR></TABLE>Just plan on having it dyno-tuned, otherwise you should consider a different upgrade.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sa21199 »</TD></TR><TR><TD CLASS="quote">its usless but looks purdy</TD></TR></TABLE>
what he said
what he said
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">
Just plan on having it dyno-tuned, otherwise you should consider a different upgrade. </TD></TR></TABLE>
w3rd, tuning is everything
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtecfool »</TD></TR><TR><TD CLASS="quote">fuel pressure regulator is more worth your money.</TD></TR></TABLE>
and will help at the dyno
TypeRuz
Nov 19, 2003 11:40 AM
EL-Teg98
Mar 11, 2002 12:20 PM
