Replace Throwout Bearing with Clutch?
Old Feb 2, 2004 | 10:33 AM
Flux's Avatar
Default Replace Throwout Bearing with Clutch?
I'm going to be installing a new clutch and flywheel soon - should I go ahead and replace the throwout bearing while I am at it even though there seems to be nothinkg wrong with it? What is the cost of a new one?
Old Feb 2, 2004 | 10:36 AM
Chris N's Avatar
Default Re: Replace Throwout Bearing with Clutch? (Flux)
Every time I've talked to someone who did a new clutch install (or every time I've helped do one.... only a few times), they've replaced the throwout bearing.
I think it is a good idea to replace it.
Old Feb 2, 2004 | 10:39 AM
Opie's Avatar
Default Re: Replace Throwout Bearing with Clutch? (Chris N)
All of the clutch kits I have seen or bought have included TO bearing. Wouldn't hurt putting a fresh one in just make sure to lube it heavily
Old Feb 2, 2004 | 10:42 AM
thk's Avatar
thk
Members Only
I think Willard replaces throw out bearings more often than he replaces clutches.
Old Feb 2, 2004 | 10:43 AM
magic hat #9's Avatar
my clutch pedal felt awful so i replaced everything. it turned out the clutch & pressure plate were in great shape, but the to bearing was dried up, degraded, and nasty. i vote to replace it.
Old Feb 2, 2004 | 10:47 AM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
Replace the throwout and the pilot, my excedy setup came with both.
Old Feb 2, 2004 | 10:50 AM
Willard's Avatar
Default Re: Replace Throwout Bearing with Clutch? (thk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thk &raquo;</TD></TR><TR><TD CLASS="quote">I think Willard replaces throw out bearings more often than he replaces clutches. </TD></TR></TABLE>
jup... #3 is going into the car this week (62,000 miles)... and I don't sit at traffic signals with my foot on the clutch.
the heat must kill them.
I would replace the bearing everytime the tranny is off.
clutch is fine on my car... just the fawking springs are crapping out.
Old Feb 2, 2004 | 11:38 AM
yoshi234's Avatar
I shoot brides
Default Re: Replace Throwout Bearing with Clutch? (Willard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">clutch is fine on my car... just the fawking springs are crapping out. </TD></TR></TABLE>
I think 234 is in da sajm boat? No slippage at all, but pedal is soft as fawk
yshi - who hates taking down the x'nz
Old Feb 2, 2004 | 11:41 AM
PM-Performance's Avatar
Default Re: Replace Throwout Bearing with Clutch? (yoshi234)
i would just to be safe, its already off, i replaced my stock clutch at like 10k miles or so and replaced it anyway .
Old Feb 2, 2004 | 11:42 AM
Stunna BEN's Avatar
Don't call it a comeback
Default Re: Replace Throwout Bearing with Clutch? (itr206)
You can if youd like, but its not 100% nessisary
Old Feb 2, 2004 | 12:09 PM
RTW DC2R's Avatar
whats the difference between a "throwout bearing" and a "pilot bearing"?
Old Feb 2, 2004 | 12:10 PM
scrap1ngsr's Avatar
Default Re: (RTW DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">whats the difference between a "throwout bearing" and a "pilot bearing"?</TD></TR></TABLE>
also what is both of their purpose?
Old Feb 2, 2004 | 12:12 PM
typer_801's Avatar
How many miles are on it? If over 30K, I'd replace it no questions asked. it's only ~$30. Well worth it to save you from pulling the tranny later if it fails. Just my $.02
Also be sure to use the special Honda lubricating grease (the name of which eludes me) on the clutch fork and TO bearing. It's like $10 from the Honda/Acura dealer.
Old Feb 2, 2004 | 12:19 PM
Chris N's Avatar
throwout bearing is the thing that connects to the shift fork thingy (excuse my bad grammar/vocabulary), which sticks out of the front of your tranny with the rubber b00t on it.
pilot bearing is the bearing you press into the center of the flywheel.
Old Feb 2, 2004 | 12:20 PM
Opie's Avatar
Default Re: (Chris N)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris N &raquo;</TD></TR><TR><TD CLASS="quote">
pilot bearing is the bearing you press into the center of the flywheel.</TD></TR></TABLE>
Again, be sure to lube heavily!
Old Feb 2, 2004 | 12:23 PM
RTW DC2R's Avatar
throwout bearing is the big *** bearing that slides on the shaft right? the one Opie wants to l00b heavily?
Old Feb 2, 2004 | 12:25 PM
Opie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">throwout bearing is the big *** bearing that slides on the shaft right? </TD></TR></TABLE>
Old Feb 2, 2004 | 12:28 PM
Chris N's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">throwout bearing is the big *** bearing that slides on the shaft right? the one Opie wants to l00b heavily?</TD></TR></TABLE>
yes.
opie is scaring me.
do you l00b up your louisville before you beatdown your local enemies?
Old Feb 2, 2004 | 12:30 PM
Chris N's Avatar
opie112 (3:29 PM 2/2/2004): lol Lubyville Slider!
Old Feb 2, 2004 | 12:32 PM
Opie's Avatar
&lt;-- Speechless, how OT we get so easy Back to topic!
Old Feb 2, 2004 | 12:56 PM
RTW DC2R's Avatar
opie, I might have to deny your offer to be a roomie at Exb0 :yikes:
Old Feb 2, 2004 | 01:13 PM
NSXjr's Avatar
yea....i think u should change it
Old Feb 2, 2004 | 02:04 PM
v-attack's Avatar
Yeah, the throwout is the one that rides on the input shaft smoothed area. The splines, and the smooth area should be lubricated before installing it all. Too much lube isnt good for the clutch disc when you start moving.
The pilot bearing is put in the flywheel, it gives the input shaft support when you apply the clutch.
Old Feb 2, 2004 | 02:06 PM
Stunna BEN's Avatar
Default Re: (opie112)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opie112 &raquo;</TD></TR><TR><TD CLASS="quote">&lt;-- Speechless, how OT we get so easy Back to topic!</TD></TR></TABLE>
ITR forum is mostly OT!
Old Feb 2, 2004 | 08:37 PM
ndtITR's Avatar
Default Re: Replace Throwout Bearing with Clutch? (opie112)
Make sure you actually put it in when you change your clutch...my friends put a new clutch in then put the entire trans back on unaware that the throw out bearing was still sitting on the tool box..hahaha...needless to say they had to take it all back apart and put it on...but yes replace it...
