'95 Accord - Unable to remove hub from driver side axle in order to replace brake rotor
Old Feb 2, 2004 | 08:30 AM
wagonboss's Avatar
Default '95 Accord - Unable to remove hub from driver side axle in order to replace brake rotor
Passenger side no problem with AutoZone hub puller. I have disconnected the lower control arm, all is swinging free, Puller won't budge it, even with long breaker bar,actually bulging the pulling tool body. Have tried sledge hammer,hosing with WD-40 and heating the hub with a torch. Don't want to go too nuts and break something. Am I missing something? Any tricks? I have done this before on a '91 Accord, no problems. 200,000 miles on this Accord, hub never been off. Any help apreciated. Thanks.
Old Feb 2, 2004 | 10:25 AM
ForceThis!'s Avatar
Default Re: '95 Accord - Unable to remove hub from driver side axle in order to replace brake rotor (wagonbo
so you already have that big *** (27mm? 30mm?) nut off and you can't remove the whole bearing from the hub? if so, get a slide hammer, bang bang bang, bearing spereates, job done and never a need to remove anything but the nut. jm2c
Old Feb 2, 2004 | 11:20 AM
Riceburner247's Avatar
If all else fails, just grab a bigger hammer.
Old Feb 2, 2004 | 11:54 AM
.bagged's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburner247 &raquo;</TD></TR><TR><TD CLASS="quote">If all else fails, just grab a bigger hammer.</TD></TR></TABLE>
Seems to be your solution to everything
Charlie Moua
Jul 1, 2013 10:04 AM
psychojason
May 10, 2011 12:23 AM
chrism2352
Nov 3, 2009 02:58 PM
crazzylowrider
Sep 8, 2008 06:38 AM
TEAM JDM-P
Aug 13, 2007 03:36 AM
