Forced F22 or N/A H23/H22 ?
Old Feb 2, 2004 | 07:38 AM
SuperShale's Avatar
Default Forced F22 or N/A H23/H22 ?
Ok, I've got a stock rebuilt F22 in my Accord right now w/ less than 1K miles. I could boost it easy with 8-10lbs of boost and hope it doesn't blow up. Or I can go to the junkyards and pick up an H23 bottom, and buy a rebuilt H22 head. Build the bottom end, and set it up for Nitrous.
What do you think?
Old Feb 2, 2004 | 08:10 AM
Broken Gearbox's Avatar
Default Re: Forced F22 or N/A H23/H22 ? (slateboy)
Turbo the F22.
Old Feb 2, 2004 | 08:12 AM
The_Todd's Avatar
Farts in the shower
Be different boost it....also if its rebuilt, just make sure its "broken in" before you crank it up y0. And take some pictures.
Old Feb 2, 2004 | 08:23 AM
eL's Avatar
eL
wah pshhhhhhhhhhh
Old Feb 2, 2004 | 09:32 AM
H22SiRaccord's Avatar
Keep the f22 and boost it. You will be able to run faster and SOHC non-vetc owns all. IMO
Old Feb 2, 2004 | 10:48 AM
ForceThis!'s Avatar
boosted F
Old Feb 2, 2004 | 10:52 AM
CD7 - Germany's Avatar
Default Re: Forced F22 or N/A H23/H22 ? (ForceThis!)
bOOOst !!!
Old Feb 2, 2004 | 03:19 PM
accordfreak's Avatar
Default Re: Forced F22 or N/A H23/H22 ? (CD7 - Germany)
i think everyone should boost their f22!!!
Old Feb 2, 2004 | 08:23 PM
twkdCD595's Avatar
boosted f.
Old Feb 2, 2004 | 09:17 PM
Default Re: Forced F22 or N/A H23/H22 ? (twkdCD595)
that is also my opinion. i will boost my f too next month....
Old Feb 2, 2004 | 11:52 PM
SuperShale's Avatar
Looks like boost it is.
Old Feb 3, 2004 | 12:25 AM
D16Z6racing's Avatar
Default Re: (slateboy)
Of your choices, boost the F22.
I'd go with a full H23 set up, no nitrious. That's me though.
Old Feb 3, 2004 | 01:29 AM
4genaccordfreak's Avatar
as seen in my signiture i am also boosting my f22... so far, already got myself a Japanese nissan 16v9 ball-bearing turbo, revhard manifold, and a 38mm Tial wastegate with .6 bar spring..(good too9 or 10 psi) if u get a well rounded setup u can run around 8 psi no problem on stock internals because of low compression.. and gaurenteed u'd spank any n/a h22a by atleast 2-3 car lengths.. no bullshit =c)
the key phrase is: turbo is the cheapest form of high horsepower gain if done right!
Old Feb 3, 2004 | 09:43 AM
Brandon's Avatar
Life is Suffering
Default Re: (4genaccordfreak)
One word. BOOST
Old Feb 3, 2004 | 11:20 AM
carolinaACCORD's Avatar
Default Re: (Brandon)
go with the most cost effective.
turbo f22
Old Feb 3, 2004 | 11:42 AM
accordguy96's Avatar
Default Re: (carolinaACCORD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by "carolinaACCORD" &raquo;</TD></TR><TR><TD CLASS="quote">go with the most cost effective.
turbo f22
In order to built a good working, strong and reliable boosted F22, it will cost you more then an H22a swap anyday. Cutting corners when boosting your motor will only lead you down the road in disaster. Do it properly the first time. Tuning is key!
Old Feb 3, 2004 | 11:45 AM
snatch13's Avatar
id go with the boosted f22... it has a lower compression so it will handle the boost pretty well... also im not a big fan of nitrous and i dont think anyone else on here is either so... if you have the money id go with a h22 and boost the **** but thats just my opinion
Old Feb 3, 2004 | 07:55 PM
91according's Avatar
Default Re: Forced F22 or N/A H23/H22 ? (snatch13)
boost and nos the f22 just use a 25 shot to get rid of the lag i have a 75 shot in my accord and i run just fine and i have 140k on her so yeah with the 75 shot of nos it beats b16s yeah badass
Old Feb 3, 2004 | 09:27 PM
Sleepy26's Avatar
boost that sucker
matchboxboy
Sep 2, 2005 09:11 AM
turbochargeb18c
Aug 21, 2005 07:48 AM
NeKe1point0
Sep 18, 2004 08:04 PM
psyphre
Nov 11, 2002 07:59 PM
