Valve adjustment Question!!
I have a 95 teg ls. The vales make a loud noise as if the rocker arms are not snug on the camshaft lobe.I adjusted them to factory specs. But I have bigger camshafts (Crane Came Stage 2). Now it says the valve setting is Intake 0.004mm and exshuast 0.008mm on the card I got with the camshafts.. My feelr gauge only has .04 and .07.
My question is there different feeler gauges. .008 seems real close. Any advice would be great thanks.
I know what the different settings on the gauge, but I didn't realize that .10=.004us. And since I have bigger cams I did't know that you have to adjust them with the lobes up. I just did it on what the Helms told me... I'll try this afternoon.
