HOW to block off bumper holes after removing headlights? DC2
Old Feb 1, 2004 | 06:36 PM
RinBlue's Avatar
Default HOW to block off bumper holes after removing headlights? DC2
want to remove my headlights This is for my weight reduction plan...How do you guys block off the holes what do you use to make it look so nice and clean???Please help What kinda materials are needed and how to pics would be excellent
Thanks H-T members
Modified by RinBlue at 11:42 AM 8/21/2004
Old Feb 1, 2004 | 06:50 PM
B2FiNiTY's Avatar
Default Re: HOW to block off bumper holes after removing headlights? DC2 (RinBlue)
cardboard? sheet metal? Anthing works...
Old Feb 1, 2004 | 07:15 PM
uNF$@#!'s Avatar
you can always have a machine shop cut/prep a piece of metal the size of the hole.. then jb weld on 2 tabs that should have a hole in place to tap into the bump assembly itself..much like the stuff realtime uses
though...im not sure what they use is metal...
Old Feb 1, 2004 | 07:42 PM
esponet's Avatar
what i did before..
new car dealer plate insert, use the back part (white) cut it to match the shape of the hole from the headlights (make it a little bigger than the hole) then duck tape it to the back of the bumper. use lots of duck tape. from the outside all you will see are white plates.
clean, easy, light and cheap.
Old Feb 1, 2004 | 08:35 PM
uNF$@#!'s Avatar
Default Re: (esponet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esponet &raquo;</TD></TR><TR><TD CLASS="quote">what i did before..
clean, easy, light and cheap.</TD></TR></TABLE>
that would work up to a certain speed
going 110+ mph on a track im sure duct tape wont hold its own for long (quack quack)
Old Feb 1, 2004 | 08:38 PM
DsITR's Avatar
Isn't there some company that makes a headlight cover for the DC?
That would probobly give the best fitment.
Old Feb 1, 2004 | 08:40 PM
baonest's Avatar
Default Re: HOW to block off bumper holes after removing headlights? DC2 (DsR)
you mean like this
Old Feb 1, 2004 | 09:04 PM
DsITR's Avatar
Default Re: HOW to block off bumper holes after removing headlights? DC2 (baonest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baonest &raquo;</TD></TR><TR><TD CLASS="quote">you mean like this
lmao.. ya, that pic is classic
Old Feb 1, 2004 | 09:12 PM
esponet's Avatar
i had mine above 110mph, i think it was around 115-118mph,(5th gear) you would be amaze how much duck tape would hold. but make sure the surface are clean and dry before you use the tape.
Old Feb 1, 2004 | 09:18 PM
TDRacing's Avatar
Take out your lights and weigh them, hardly worth taking out in my opinion. more hassle than its worth
Old Feb 3, 2004 | 01:02 PM
RinBlue's Avatar
Default Re: (TDRacing)
really dont need the lights so its worth it to me. so i could just use anything practically right?
dont really want to use duct tape to secure and other ideas
Old Feb 3, 2004 | 01:03 PM
Stunna BEN's Avatar
Don't call it a comeback
Default Re: (RinBlue)
If you cant duck it, **** it.
Old Feb 3, 2004 | 01:24 PM
eghonda's Avatar
Default Re: (-BEN-)
duct tape was known as "100 mile an hour" tape back in the day when they used to patch up fighter planes with it. duct tape has also been used by many in nascar and they travel at ~185mph so i think you are in good hands.
Old Feb 3, 2004 | 03:51 PM
Chemicalviper's Avatar
Default Re: (eghonda)
Wire mesh so you still get good airflow and maybe screw in the mesh in the back of the bumper ?
Old Feb 3, 2004 | 04:10 PM
mikestypeR
Guest
Posts: n/a
Default Re: (Chemicalviper)
duck tape yO! that would be the easiest plus you aint looking to make a fashion statment your going racing ... p.s. stay out of the wall
Old Feb 3, 2004 | 04:39 PM
NW94RS
Guest
Posts: n/a
Default Re: (mikestypeR)
just leave your passenger headlight out and run a short ram. most effective
Azn Mug3N (01 em2)
Honda Civic (2001 - 2005)
May 19, 2007 05:38 PM
JonLude
Jan 15, 2006 09:55 PM
RinBlue
Feb 5, 2004 09:04 AM
RinBlue
Feb 1, 2004 09:07 PM
