1997 ITR "water main"?
I know its a long shot, and should proably ask
the ITR forum, but those guys will proably just
have some smart *** remarks. Any ideas of where
to get this or what its called, and how much they go
for would be a great help.
Its the main water pipe that runs along the back of the block.
Its next to the number 11. Thanks
elwood
elwood
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">I see 8 different number 11's, you're going to have to specify.</TD></TR></TABLE>
......ahaha.....oh man.....i was so excited I found what I was looking for,
I didnt even look at the rest of the picture. the second 11 on the left
side bottum of the picture, the pipe that has the two nipples on it, that
runs across the back of the block.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">I know it runs from the water pump if that helps you any.</TD></TR></TABLE>
not really, but thanks for trying.
I took two of them off two different engines today, so I dont
need help on what they are or what they do, just where to get
them or how much its going to cost me? Thanks.
From http://www.acuraautomotiveparts.net go to the "waterpump-sensor" fische. It's called the PIPE, CONNECTING. On my 1998 GSR it's number 9 and cost $29.65. I believe different motors use different pipes so you need to specify which engine it's for.
edit: you did specify which engine, my bad.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MR5sARECOOL »</TD></TR><TR><TD CLASS="quote">you can use the one off of the gsr with easy mods if you cant get the c5 one. I've got a 00 itr block w/ a gsr pipe</TD></TR></TABLE>
thing is.......i have been told this will fit on a d16z6, and I already
have everything else I need for the oil cooler to fit, just need the
water pipe that fits.
thanks for the help.
comparing the drawings I have found, they still look totally different.
You can always modify the water pipe you have now. Drill and tap and insert some brass barbed fittings. I think it'll hold up as long as the water pipe is a decent wall thickness.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stumpyf4 »</TD></TR><TR><TD CLASS="quote">You can always modify the water pipe you have now. Drill and tap and insert some brass barbed fittings. I think it'll hold up as long as the water pipe is a decent wall thickness.</TD></TR></TABLE>
good idea, I was actually just going to weld the nipples on to my stock pipe.
