Hondata IM gasket..few questions.
does the hondata imgasket really lower intake temps by 15-20%?
i always used oem im gaskets but recently i was in my local shop and noticed the hondata im gasket and did a little research and hondata says it lowers intake temps by 15-20%..can anyoneverify this or add to this info?...would it be worth using this gasket for a street built head?
My experience was more like 10-11%. I have Hondata and datalogging, so I just watched the IAT sensor readings. At 200 degrees, that's 20 degrees cooler intake temps-it is good for a few hp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwn7 »</TD></TR><TR><TD CLASS="quote">plus they're reuseable, so after awhile it will pay for itself. i pull my intake mani off at least 4 times a day.</TD></TR></TABLE>
Me too!
Me too!
yea..i dont pull my im very often and for the price they are going for i might as well just buy a few and thrwo them in my stock pile of replacment gaskets..might as well give it a shot..i got nothin to lose
How well it works depends upon the way you drive, and where you drive. Naturally the gasket will work better when there is a lot of airflow both through the manifold and through the engine compartment. So if you do a lot of highway driving, it will be more effective than if you do primarily stop and go driving where heat soak will become a major factor.
does anyone know if they make it for d16z and where i can get one? sometime this week i'm gettin a skunk 2 intake manifold so since i'm gonna be changin the manifold, mind as well get a new gasket for it... thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicr2gs5 »</TD></TR><TR><TD CLASS="quote">does anyone know if they make it for d16z and where i can get one? sometime this week i'm gettin a skunk 2 intake manifold so since i'm gonna be changin the manifold, mind as well get a new gasket for it... thanks</TD></TR></TABLE>
http://www.hondata.com
hondata makes a great product in their im gasket, but a more affordable im gasket that is nearly identical to the hondata is the an-r.
an-r.com
either way you will have a cooler im
an-r.com
I've got the hondata IM gasket, and after pulling my motor apart for this rebuild, the gasket is all nasty-looking. The intake ports seemed to have shrank (i.e., the holes that the air flows through are now smaller and look like it will restrict/disrupt the flow of air). Am I the only one who has had this problem, and should I reuse it?
Im using the Hondata Gasket and the manifold does feel a little cooler but the other advantage to it is. If you remove your manifold alot or any its reusable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by servion »</TD></TR><TR><TD CLASS="quote">I've got the hondata IM gasket, and after pulling my motor apart for this rebuild, the gasket is all nasty-looking. The intake ports seemed to have shrank (i.e., the holes that the air flows through are now smaller and look like it will restrict/disrupt the flow of air). Am I the only one who has had this problem, and should I reuse it?</TD></TR></TABLE>
And has enyone looked into this???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blykins »</TD></TR><TR><TD CLASS="quote">I have it and my intake manifold gets just as hot as it did before I put it on. I dont notice a difference.</TD></TR></TABLE>
same with me
i have it and i dont notice any difference at all
i mainly got it cuz its reusable
same with me
thats the one thing i dont like about the hondata gasket, they get deformed way too quickly. after being used for maybe about 100miles, i pulled mine and the ports were all squished out of position. thats probably causing lots of disturbance. and all the bolts were tqed to spec so thats not a factor. I think the material used is just too soft.
yes. I have some in stock. $60+shipping
yeah, it works much better if you also have the insulating washers. Otherwise the nuts touch the studs, which are in the mani, and you still get heatsoak.
Not a bad idea to reroute your coolant lines that go to the TB/IM while you are at it.
patastinky
Dec 4, 2004 07:32 AM
sleepin91teg
Jun 20, 2004 01:05 PM
B18C2_sedan
15
Mar 7, 2004 11:17 PM
1.8T_EG
Apr 10, 2003 04:06 PM
