passing smog on ls/vtec possible???
Old Feb 1, 2004 | 01:47 PM
vaporDA6's Avatar
Default passing smog on ls/vtec possible???
hello everyone i just got a quick question is it possible to pass smog with a ls/vtec...stock b18a short block with just i/h/e and a itr intake manifold and also a chiped Pr3 ecu? the head is a b16a
Old Feb 1, 2004 | 01:50 PM
typeRSXS's Avatar
if you got money, it's possible. other then that, there's no way my friend could have passed his smog test.
Old Feb 1, 2004 | 01:54 PM
Kendall's Avatar
It depends upon the engines tuning, you can tune it to be emissions friendly, but don't expect it to be all that cheap.
Old Feb 1, 2004 | 03:30 PM
riceball777's Avatar
Default Re: passing smog on ls/vtec possible??? (vaporDA6)
nothing passes smog here in cali
thats why anyone that mods their cars here just do illegal smogs
Old Feb 1, 2004 | 04:34 PM
B_CRUZ!'s Avatar
Default Re: passing smog on ls/vtec possible??? (riceball777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaporDA6 &raquo;</TD></TR><TR><TD CLASS="quote">hello everyone i just got a quick question is it possible to pass smog with a ls/vtec...stock b18a short block with just i/h/e and a itr intake manifold and also a chiped Pr3 ecu? the head is a b16a </TD></TR></TABLE>
you won't pass legally with that ECU. you might be able to get away with the visual test if you put on a valve cover with the VTEC sanded down.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 &raquo;</TD></TR><TR><TD CLASS="quote">nothing passes smog here in cali
thats why anyone that mods their cars here just do illegal smogs</TD></TR></TABLE>I beg to differ. I had a GS-R 94 EH hatch and it passed with ease. I have had a few buddies with dohc vtec motors that have passed with cams and built heads. its all in the tuning.
Old Feb 1, 2004 | 04:38 PM
ggangtong81's Avatar
why is it hard to pass the smog?? is that also true in NY?? cuz i am planning to do ls/vtec and if i won't be able to pass the state inspection, i mind as well just save money on turbo. thanks.
Old Feb 1, 2004 | 04:40 PM
B2FiNiTY's Avatar
Default Re: passing smog on ls/vtec possible??? (B_CRUZ)
It will fail visual in CA unless you have a complete swap that is bar ref. No half and half setups.
Old Feb 2, 2004 | 09:33 AM
vaporDA6's Avatar
Default Re: passing smog on ls/vtec possible??? (B2FiNiTY)
i will be smogging this car in phoenix arizona anyone have experience with smogging cars there?? ive heard that they dont do visual.?
Old Feb 2, 2004 | 09:36 AM
B_CRUZ!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">It will fail visual in CA unless you have a complete swap that is bar ref. No half and half setups. </TD></TR></TABLE>
trust me... I have seen dumb smog tech's not notice the vtec solenoid on LS/VTEC set ups.... all they did was remove the spark plug cover and shave down the dohc vtec.
Old Feb 2, 2004 | 09:40 AM
lapok25's Avatar
Depend on which state. I know in Kali it is impossible. I heard i Hawaii as long as you have a CAT you are OK.
Old Feb 2, 2004 | 09:54 AM
vaporDA6's Avatar
Default Re: (lapok25)
has anyone here that lives in phoenix smoged their car with an ls/vtec in there and passed??
Old Feb 2, 2004 | 10:04 AM
thaiphob's Avatar
Nikon!!!
Default Re: (vaporDA6)
as long as you pass the sniffer using the usual methods, you can pass anything in phoenix!
Old Feb 2, 2004 | 10:19 AM
crazzeboost's Avatar
Thats not true because im running a b18c1 wid e/h/i and itr cams and i passed smog just fine, plus i was the few unlucky ones that got a test only station so they were alot more strict, still cost some money to get the car smogged tho, cali sucks for that one reason!
Old Feb 2, 2004 | 10:49 AM
JDM_Risa's Avatar
Default Re: passing smog on ls/vtec possible??? (crazzeboost)
thats completely wrong two of my friends ls/vtec pass smog
was ls block with usdm itr piston b16 head milled .003 itr cams too all stock bolt ons......
then a stock ls block with gsr head milled .003 itr cams skunk im aem ls cai pass smogged too this set-up we did all home installation as long everything plugs into place you koo...
this is in san jose, ca
Old Feb 2, 2004 | 10:57 AM
JDM_Risa's Avatar
Default Re: passing smog on ls/vtec possible??? (GunMETAL_TEgRa)
the stock bottom end ls/vtec used a stock ls ecu
the built one had hondata stage 3
Old Feb 2, 2004 | 12:13 PM
vaporDA6's Avatar
well at least that gives me some hope in passing smog in phoenix. with some tuning
joshua22
Nov 3, 2012 04:29 PM
jdmdc2boi12
Dec 12, 2008 07:39 PM
DC4 me
Dec 2, 2006 10:48 PM
alain pestanas
Jan 28, 2005 11:30 AM
