Help Compression Test 200-200-210-215 ????? is that bad
Well I have a fully built and bored out GSR motor... pretty sure the head gasket is blown.. would those compression numbers be conducive of a blown HG.... any suggestions thanks... i lose alot of coolant without it leaking and burn alot of oil.
Chris
Chris
I used a cometic head gasket when the motor was put together.. .think i will swap it out with a stock honda gasket.. unless there are better suggestions... it also has a block guard on it
i dont remember the thickness... yes its an all motor setup... it was a triple layer gasket...
I noticed boring it out to a 2.0 definatly gave it some more torque..
not trying to say you do not know what your doing. But did you get the car to normal oper temp? Sometimes people forget
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TopEndGSR »</TD></TR><TR><TD CLASS="quote">believe it was thicker</TD></TR></TABLE>
As a general rule of thumb, thicker headgaskets tend to have more problems than thinner ones.
Before we did the compression test you mean?
i dont believe it was at the complete normal temperature... that could change things.???
I am not pretend to know everything because there are a lot of things i dont know... so any info is appreciated
I think I will retest them tomorrow morning once i take it to the shop... Think i am replaced the HG anyway.. i burn way to much oil and lose too much coolant.. plus its leaking out of 3 cam seals, vtec sylonoid (sp?), and was leaking out the bottom of the distributor...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by len »</TD></TR><TR><TD CLASS="quote">Those numbers look normal to me.</TD></TR></TABLE>
Those numbers don't look very bad at all. Of course I just pulled my brothers head for similar numbers and the gasket was just barely blown. He had overheating issue though. How do the spark plugs look?
You really need to get a leakdown test done to fing out what your problem is.
Are you burning off the coolant or is it just mixing with the oil? It sounds like you have some major problems. Burning oil and losing coolant combined is not a good thing.
Check to see if the coolant is contaminated with oil and the same thing with the oil - check to see if it has coolant in it.
The 2 spark plugs on the ends 1 and 4 the prongs were white... and yes I am having an Overheating problem too.. Rather Badly... radiator replacement and thermostat change didnt cure it...
might do a leakdown test tomorrow
Worse case scenario, it could be a cracked sleeve... but I doubt that. Pull the head and have a lookie, replace the head gasket if all looks well, and keep your fingers crossed.
Maybe your torque wrench is off. Thus the head bolts were too loose?
Now that you say it is overheating I would definetly pull the head.
Worst case scenario is that the block or the head are cracked.
the cometic all-motor hg is thinner than 82mm, the boost/nitrous hg is thicker than 82mm. i had the same problem in my 94' b18c1 before it went...check the gaskets in the sparkplug tubes and some of your vac lines to see if there clogged.
i did a complete motor build.. dont think i skipped anything.. just no hondata yet
