friend gave me 2 coils, but have different part #'s
i have a 90 teg, distributor is known for blowing so i keep a spare dizzy in my trunk. My friend gave me 2 coils: both TEC: tc-05a and tc-07a
They both look identical, can i use them?
tc07a is the one I pulled from my 91gs
the only difference that I will find is the mounting points.
I used a 90 igniter on my 92 gsr
they both had different numbers the only change was that
the mounting bracket was different.
a 92 gsr is obd1 and 90 ls is odo0 thats why the dizzys are different so i think the coils would be too..
ok now .. i did a OHM test and all three read the same primary 2.5 and secondary
30... ohm meter set @ rx1k
only difference is shape...
on the coils
as for the igniter the difference is the bracket that holds them in place..
on the coils
