92-95 civic hatch gastank fit 00 civic hatch
Old Feb 1, 2004 | 10:08 AM
buck02's Avatar
Default 92-95 civic hatch gastank fit 00 civic hatch
im tring to find out if the 92-95 civic hatch gastank will fit in a 00 civic hatch please help
Old Feb 1, 2004 | 01:22 PM
Spartanic's Avatar
Default Re: 92-95 civic hatch gastank fit 00 civic hatch (h22civic2)
call up honda and ask for the part numbers for the 92-95 Civic gas tanks and the 96-00 Civic gas tanks. If they are the same numbers then they will fit. You might as well replace the fuel pump while your at it with a higher flowing fuel pump. Check out http://www.jdmgears.com for your fuel pump needs. It'll be a good investment if you ever swap over to the bigger B series VTEC motors.
Old Feb 1, 2004 | 01:24 PM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22civic2 &raquo;</TD></TR><TR><TD CLASS="quote">im tring to find out if the 92-95 civic hatch gastank will fit in a 00 civic hatch please help</TD></TR></TABLE>
Anything fits if you have a welder.
Old Feb 1, 2004 | 09:42 PM
boostn420's Avatar
I wouldnt do it if your keeping it obd2 because there are sensor on the newer tank and youll get check engine lights without them.
Old Feb 2, 2004 | 12:43 PM
buck02's Avatar
Default Re: 92-95 civic hatch gastank fit 00 civic hatch (boostn420)
well im running a piggy back im not worried about the check engine light but will it fit that what im worried about
kmeng
Jul 10, 2008 11:16 AM
RobertMcDonald
Jul 21, 2003 11:38 PM
