need help on suspension
Old Feb 1, 2004 | 01:14 AM
TspEk9's Avatar
Default need help on suspension
ok so.. my car ( ek9 )got jacked and i got it bac and its was a total mess....i only had 2 wheels in the back..none in the front..and no suspension on the font...so it sited in my bac yard wit no front suspension for a while until i got suspension from an eg..bolted right up..then when i drive the car seems to want to turn slighty to the left when i let go of the steerin wheel...does anyone know what the problem is?
Old Feb 1, 2004 | 07:30 AM
vtekstorm's Avatar
Default Re: need help on suspension (TspEk9)
get an alignment done first. and if its still pulling check your tire pessures also. if that dont work then something might be bent undernieth goodluck
Old Feb 1, 2004 | 12:01 PM
TspEk9's Avatar
aight thanks man. good lookin out
Old Feb 1, 2004 | 01:10 PM
Spartanic's Avatar
Check your suspension bushings and make sure they are in good condition. In order to do so jack up your car, get under need and wiggle your suspension pieces back and forth. If there is movement then you may have some bad bushings.
To check your lower control arm bushings jack up the car then grab the wheel by the 6 and 12 o'clock position. Wiggle it back and forth, there shouldn't be any movement. If there is then you've got a bad lower control bushing. If you ever do decide to replace the bushings then we reccomend you replace them with Energy Suspension's Hyper Flex bushing kit. For more info on these check out http://www.jdmgears.com or email us at info@jdmgears.com.
99tegjawn
Suspension & Brakes
Apr 30, 2011 08:31 AM
Tippyman
Sep 2, 2006 01:24 PM
FF-sean
Nov 1, 2004 05:07 PM
