Did I fried my amp?
Old Jan 31, 2004 | 10:04 PM
special_edition's Avatar
Default Did I fried my amp?
I got a Sony 4-channel amp and when I was about to relocate it I accindentally took the ground wire and touched the amp which cause a spark. Now the amp power light glows amber when I try to power it up. Green light means power and protection suppose to light up red...i think. But anyways, I didn't shorted the speaker output so could it possibly be in protection mode? or did I just fried the whole amp?
Old Jan 31, 2004 | 10:57 PM
Full Race A6's Avatar
Default Re: Did I fried my amp? (special_edition)
ulway unhook the negative side of the battery before doing any wiring
Old Feb 1, 2004 | 01:45 PM
Enfo's Avatar
does the amp internal fuses?
if so, check them...if they are blown that will cause the amp to protect, other things that might happen could be, a solder ball melted off due to the crossing, or something on the board blew.
Old Feb 2, 2004 | 06:18 AM
Default Re: Did I fried my amp? (Enfo)
so did you blow it?
Old Feb 2, 2004 | 11:11 AM
Yeah, I checked the fuse and it didn't blow. I even open the amp to see if I can detect any burnt or out of extrodinary circuitry. I not a electrical engineer so I don't know what to look for..hehee.
Funny tho, how my kenwood amp had an additional ground point on the amp frame itself. Never ground that but I assume nothing major will happen to an amp if a ground hit the frame. Guess, I was wrong Why don't they built an amp with reset button when something like this happen....arghhh
Old Feb 2, 2004 | 01:51 PM
KW2000's Avatar
all i saw was sony and amp and if its not work 90% chance u blew it...i fried my old sony 760 2 channel..it got dominated by 2 subs.....umm....they have a 1 year factory warrenty take it back where u got it and see if they can help u send it in...it didn't cost me a dime to get it fixed but i didn't have it for like a month or 2 kinda sucked but yea.
Old Feb 2, 2004 | 09:46 PM
Enfo's Avatar
I'm gonna agree with KW93LUDE on this, if its under warranty, send it back and have it repaired/replaced. cause if something on the board did blow, you dont wanna try and fix it :D
Old Feb 3, 2004 | 03:02 PM
Amp is over 2 yrs old. No warranty. Going into the trash can unless someone wants it to mess around.
Old Feb 3, 2004 | 03:30 PM
Spider Man's Avatar
Default Re: (special_edition)
i will take amp.
I'm in San Jose.
Drop me a line
diamond1301@hotmail.com
Old Feb 3, 2004 | 03:31 PM
E M P I R E's Avatar
hehe, you're gonna love this, this happened to me, not long ago,
open up the amp, (if you want), and right on top of every amp, there are black square units, there is probably 10 of them on a 2 channel amp. they are all lined up, anyways, one of those is burnt out, you can see it because of all the black smoke around its area,
run down to a chip factory, they are 60 cents - 1$ , get one of those, and put it in,
worked for me,
do this, you should be fine
ps. i have a new problem now, due to pulling wire accidentally, now my fuse burns out instantly as soon as i put 1 in, but its not dead.
Ricey McRicerton
Audio / Security / Video
Jan 25, 2004 10:41 AM
intenseEK
23
Dec 17, 2003 06:54 PM
EBP_SI
Apr 29, 2003 02:55 PM
BoroDB8
Oct 15, 2001 01:09 AM
