finnaly night shots of Defi D gauges
i finnaly wired in my gauges. some were intersted in seeing th illumintion. its a lil bright for my tast, i will probably add some resisters to dim the leds. here goes, sorry for the blured pics
to anyone w/an oil pressure gauge...it it normal for the pressure to fluxuate?
also, i seem to have tapped into the wrong wire for the primary o2. i used the blc/wht wire. seems like that is wrong. does anyone know which is correct? thanks(98ek hatch here)
Looks fawking sweet.....and with the oil pressure guage fluctuating, the higher the revs the higher the pressure and vice versa, completely normal, unless its going max to low then something is wrong.
thanks, glad to know that the fluxuating gauge is normal. i tapped the wire on the ECU side. i think i may have accidently tapped the 2ndary o2 wire....which i don't have
I am gettin the same guages, but I just realized my CTR benzel has Yellow Needles, not red!! DOH!! I wish I could switch them out!
EK9 BEEZLER
Jun 7, 2005 09:58 AM
xxh23fuzionxx
Aug 25, 2003 07:24 AM
