**HELP WITH PISTON QUESTION**
Old Jan 31, 2004 | 04:30 PM
Mr HYDE's Avatar
Default **HELP WITH PISTON QUESTION**
ok i got a b18c1 planning on building the head. now time for bottom end i looked up at c-speed http://www.c-speedracing.com/h...c.php that c1 and c5 have the same bore. now my question is will the p73 itr pistons fit into a gsr block with out boreing. i know it may be a stupid question but help
Old Jan 31, 2004 | 04:32 PM
Mr HYDE's Avatar
Default Re: **HELP WITH PISTON QUESTION** (gen 5 hatch)
i thought about the ctr pistons but the car is a daily driver so i dont want crazy compersion
Old Jan 31, 2004 | 04:41 PM
Supernatural's Avatar
depending on the condition of the block...if it is in good condition and has low miles....just re-hone and put the standard sized pistons....if you have to bore the blcok then go with the oversized type r pistons....but just go and check with a machine shop
Old Jan 31, 2004 | 06:45 PM
Kendall's Avatar
If there is enough wear to require reboring the cylinders, then you should be able to locate a set of P73 pistons with a .25 overbore.
Figgy1682
Aug 1, 2007 09:55 PM
StockBlockRob
Dec 9, 2004 09:46 AM
FrankEXsteiN
Nov 24, 2002 02:02 AM
Red_Si
Jun 12, 2002 08:13 PM
