what would you do?
Old Jan 31, 2004 | 01:17 PM
DsCivicEx's Avatar
Default what would you do?
Today I got my bike back and I was pulling it into my shop. I noticed I ran over a small screw and when I removed it no air leaked out. It didnt penatrate real deap but enough to cuase wonder. Would you worry about it and ride or would ya replace it right away?
Old Jan 31, 2004 | 01:29 PM
slylos's Avatar
Default Re: what would you do? (DsCivicEx)
Ride it for a couple of days locally and see what happens. You should be ok, you'll probably always have little cuts and stuff especially in your front tire . . .
Old Jan 31, 2004 | 01:31 PM
DsCivicEx's Avatar
Default Re: what would you do? (slylos)
this is in my rear tire.
Old Jan 31, 2004 | 02:58 PM
Veritas-Aequitas's Avatar
Grumpy Old Man
If you replace your tires every time you get a small piece of glass or metal in them your just throwing your money away IMO. But that doesn't mean you can run over a box or screws and expect everything to just fine either.
Like the other guy said just ride around on it for a while and see how it does. I usually ride around locally and get it pretty warm then go home and put some water with some soap in it on the hole. Then I proceed to pull at it and try and open it as much as I can to see if any air comes out . If it passes that test then it's guaranteed by Darwin for 150 mph+
Old Feb 1, 2004 | 08:11 PM
Honky-Tech's Avatar
I'd ride over to a local tire shop and have em take a look at it....somethin like that they'll do for free, plus you'll get good advice(not dissing your guys' opinions)
Old Feb 1, 2004 | 08:43 PM
less-srt's Avatar
Default Re: (TTSR34)
i agree with you, better safe than sorry
Old Feb 2, 2004 | 04:05 AM
busa1300's Avatar
If it dosn't leak it probly good to go.
Old Feb 2, 2004 | 07:35 AM
tonydatyga's Avatar
Default Re: what would you do? (ReBornGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReBornGSR &raquo;</TD></TR><TR><TD CLASS="quote">Like the other guy said just ride around on it for a while and see how it does. I usually ride around locally and get it pretty warm then go home and put some water with some soap in it on the hole. Then I proceed to pull at it and try and open it as much as I can to see if any air comes out . If it passes that test then it's guaranteed by Darwin for 150 mph+ </TD></TR></TABLE>
That's some pretty bad information...
Old Feb 2, 2004 | 01:04 PM
Grumpy Old Man
Default Re: what would you do? (tonydatyga)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonydatyga &raquo;</TD></TR><TR><TD CLASS="quote">
That's some pretty bad information...</TD></TR></TABLE>
It was a joke tony, didn't you notice the darwin refrence and the at the end?
Old Feb 2, 2004 | 02:46 PM
Z's Avatar
Z
Old User.
Check the tire pressure, let it sit for a while then check it again. Then ride it for a half hour or so and check it again. If it's still holding it's probably fine. I'd check it often though.
Honda Motorcycles
27
Apr 25, 2007 10:04 PM
EngineNoO9
Honda Motorcycles
Apr 1, 2006 06:48 PM
Odiedogcx
Honda Motorcycles
May 23, 2005 11:32 PM
Blk03SI
Honda Motorcycles
17
Jan 29, 2005 04:13 PM
pwnd
Honda Motorcycles
31
May 8, 2004 06:44 AM
