searched...jdm hid headlight fit into non hid front
Old Jan 31, 2004 | 10:04 AM
Nishant's Avatar
Default searched...jdm hid headlight fit into non hid front
I finished my conversion but i want to get hid headlights. right now i have non hid headlights. i read somewhere that the radiator supports are different for both. if thats true, would i still be able to fit the hid headlights without modification?
Old Jan 31, 2004 | 10:06 AM
Kicker773's Avatar
Default Re: searched...jdm hid headlight fit into non hid front (swtxaznrac3r)
no its not..
Old Jan 31, 2004 | 10:08 AM
Nishant's Avatar
Default Re: searched...jdm hid headlight fit into non hid front (Kicker773)
no its not what? the same
Old Jan 31, 2004 | 10:12 AM
Kicker773's Avatar
its the same..hid or non hid headlights will fit.it will be a lil tight with the hid headlights but will fit due to the hid housing.
Old Jan 31, 2004 | 10:13 AM
Nishant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kicker773 &raquo;</TD></TR><TR><TD CLASS="quote">its the same..</TD></TR></TABLE>
thanks...now i gotta go find some jdm hid headlights
Old Jan 31, 2004 | 02:48 PM
jdmspoonitr's Avatar
If you have AC the HID ballasts will not go right in. You have to carefully rebend your AC lines to make the lights fit flush. You might also have a problem with the ballast rubbing against the washer fluid bottle. The jdm R's have a different washer bottle for the 98Spec and newer.
Old Jan 31, 2004 | 03:22 PM
97 TYPE-R 312's Avatar
Default Re: searched...jdm hid headlight fit into non hid front (jdmspoonitr)
what he said!
-Victor
Old Jan 31, 2004 | 03:37 PM
One Bad GeeSeeR's Avatar
yup thats true. i had to do that with my jdm front end. i had to bend the ac lines and remove the washer fuild.
Carlo
Old Feb 2, 2004 | 09:41 AM
Mugen Type R's Avatar
cant you just take it out, make it busted in a bit and fit it back over the back of the light
Old Feb 2, 2004 | 09:48 AM
Seedc2's Avatar
Default Re: (Type R 98-870)
does anyone know what type of bulb the hid housing is? non hid is 9006 correct?
Old Feb 2, 2004 | 10:10 AM
canuck-mx6's Avatar
Default Re: (kendogg)
Bulb is stock D2S bulb. You can get them from ebay, or from you local Honda dealer. Its the same bulb that the s2k uses
laocivic
Lighting
Nov 4, 2007 07:28 PM
Brain'Z
Mar 27, 2007 03:44 AM
JDMStilez
Feb 4, 2005 04:46 PM
rough_draft
Jun 4, 2004 03:20 AM
ILOVEGIRLS
Feb 8, 2003 07:31 PM
