Anyone have any instructions to painting '97 civic headlight housings?
hey man i did that in my car its fairly easy just take the plastic covers off by heating the clear part that meets up with the light grey part with a hair dryer or heat gun take screwdriver and pry apart dont put much force on it or you will break something then once it is apart you have to unscrew it from the housing you can also give yourself clear corners while your at it anyways use clear silicon or something like that and mash them back together and your done make sure you heat it up again as you put it back together or it wont seal properly
This has been covered a bunch of times. I can't find it but Chris y0! or something like that made one.
standbackimapro
Mar 9, 2008 02:46 PM
Hatchdude
Jan 13, 2004 11:10 PM
