JDM ITR LSD in LS Transmission?
Old Jan 31, 2004 | 07:51 AM
speedy108's Avatar
Default JDM ITR LSD in LS Transmission?
installing gear type jdm type R LSD into 94' integra ls trans. OEM LS ring gear center bore is too small to fit over the LSD. has anyone had this problem as of yet? I am not sure if i should just machine the center of the gear or purchase a new gear, or worse yet another Diff.
thank you in advance for any advice.
Old Jan 31, 2004 | 08:23 AM
JeffS's Avatar
Default Re: JDM ITR LSD in LS Transmission? (speedy108)
Find a GSR or ITR 4.40 ring gear to use and throw your LS one in the trash.
Old Jan 31, 2004 | 08:30 AM
speedy108's Avatar
Default Re: JDM ITR LSD in LS Transmission? (JeffS)
thank you for your info. couple of questions:
by doing that i will be changing the final drive? yes / no?
i prefer the LS raito over the GSR's
is the GSR stronger?
will it weaken the LS one very much if we machine it to fit?
Old Jan 31, 2004 | 08:55 AM
JeffS's Avatar
You're right. I'd forgotten the LS used the 4.266. I don't know about the machining.
You'd be better off asking in a different forum though. ITR owners don't generally use LS transmissions.
Old Jan 31, 2004 | 08:59 AM
speedy108's Avatar
thank you, yea we will be making enough power to need the taller gears. it is also nice to be able to run over 140 vs right at or just under with the others. if anyone else knows about this problem, please let me know.
Old Jan 31, 2004 | 09:16 AM
ZygSpeed's Avatar
Forced induction forum guys might be able to help.
Some of them use an LS box in their turbo drag cars.
Old Jan 31, 2004 | 06:00 PM
TwistedHatch's Avatar
Default Re: JDM ITR LSD in LS Transmission? (zygspeed)
i put a jdm type r diff into my 96 ls tranny........you need to change the diff bearings and you have to use the gsr ring gear and countershaft thus changing the final drive.....i had the tranny on my b20 turbo and my b16 turbo and it worked awsome......planning on using it on my new turbo setup on gsr shortblock with type r head.....
Old Jan 31, 2004 | 07:28 PM
Dan GSR's Avatar
Default Re: JDM ITR LSD in LS Transmission? (TwistedHatch)
also keep in mind you will need an itr or gsr counter shaft
Old Feb 5, 2004 | 02:59 PM
shawn_crx's Avatar
Default Re: JDM ITR LSD in LS Transmission? (Dan GSR)
How about an CTR LSD into an LS
Old Feb 19, 2004 | 03:56 PM
someday's Avatar
how much whp can the itr lsd handle
HondaAddict91
Transmission & Drivetrain
14
Jan 9, 2017 07:11 PM
xzodiackillerx
Feb 6, 2012 08:40 PM
R.Storvick
Oct 22, 2009 12:58 PM
dash
Aug 14, 2006 02:06 PM
speedy108
Jan 31, 2004 10:20 AM
