gsr acting weird at low rpms
Old Jan 31, 2004 | 01:21 AM
MajorPayne's Avatar
Default gsr acting weird at low rpms
my gsr just started doing this recently when i drove to sc, when i am at low rpms (0-2000) and i hit the gas, it doesnt act like im even giving it gas for a second, then all of a sudden it pulls and feels normal afterwards, like theres just some lag in btw the time i hit the gas and the time it actually accelerates, it doesnt do it all the time though, do i need to run some fuel injector cleaner through it, is it just bc of the cold weather outside? or any other ideas of what might be the culprit?
any help would be great, thanks
Old Jan 31, 2004 | 08:31 AM
Lewie's Avatar
I'm here for the gangbang!
I had that happen w/ my old neon. You will want to check the fuel system to make sure it's clean. Also, it could be your distributor. That's all that I can think of right now.
Old Jan 31, 2004 | 09:37 AM
StreetwizeRacin2's Avatar
Dude, my GSR is doing this too, its a 2000. At low RPM at half throttle or less it sort of misfires or backfires, doesnt go, then it stops and moves, car is noticeably sloiwer when it acts up too.
Old Jan 31, 2004 | 10:33 AM
agrn93ls's Avatar
Default Re: gsr acting weird at low rpms (gsr1775)
my gsr does it but only around 1k-2k rpm if im coasting with out giving it gas and then ease into the gas, but only when the engine is cold and trying to idle up. its doing that because my idle is funky and so i think it becuase of the fast idle valve but if you give it more than about 10-15% throttle and it dosent pick up then you have something wrong. does your car have a surge at idle? like idle up and down when the engine is cold and it is warming up? if so then that is why, its trying to idle but its not stable and it will affect the very low rpm acceleration. if not then its not the ignition maybe a plugged fuel filter, if youve never changed your fuel filter try it, you should just because anyway, im a mechanic and that is one thing people hardly ever remember to do.
Old Jan 31, 2004 | 11:40 AM
MajorPayne's Avatar
ok thanks for the suggestions, yeah it doesnt jump around when it idles, i think im going to try the fuel filter and maybe some injector cleaner, hopefully that will solve the problem, thanks again
Old Jan 31, 2004 | 07:54 PM
hotintegranights's Avatar
Default Re: (gsr1775)
if the car feels lazy check your ignition timing and might also check your cam gear timing make sure the timing belt dint jump a teeth.
Old Jan 31, 2004 | 11:41 PM
MajorPayne's Avatar
cool, thanks for all the help guys
Old Feb 3, 2004 | 08:30 PM
stumpyf4's Avatar
Default Re: (hotintegranights)
Agreed could be timing since timing will affect throttle response.
Also could be fuel, as soon as your go to wide open throttle the manifold vacuum change should raise fuel pressure dumping more fuel. If something is bloking the fuel then it won't accelerate as quickly. When was the last time you changed your fuel filter?
Old Feb 4, 2004 | 09:31 AM
MajorPayne's Avatar
yep already on it, doing that in a day or so, also running some fuel injector cleaner through, ill let you know if it helps, hopefully that will take care of the problem
Old Feb 4, 2004 | 12:10 PM
4U2NV's Avatar
Also check your throttle cable and make sure it's nice and snug...
Old Feb 4, 2004 | 01:42 PM
MajorPayne's Avatar
Default Re: gsr acting weird at low rpms (4U2NV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4U2NV &raquo;</TD></TR><TR><TD CLASS="quote">Also check your throttle cable and make sure it's nice and snug... </TD></TR></TABLE>
i had already tried that, im pretty sure it has to be the injectors or fuel filter...its looking like the fuel filter though, thanks for the help guys
Old Feb 8, 2004 | 04:25 PM
did you find out what it was? I cant find my problem
Old Feb 16, 2004 | 02:30 PM
bu mp
Old Feb 23, 2004 | 03:20 PM
MajorPayne's Avatar
Default Re: (StreetwizeRacin2)
just to let everyone know, i ran some fuel injector cleaner through to see if that helped, didnt help much, maybe a little, but then i changed the fuel filter, and cut the old one open (which by the way hadnt been changed ever i dont believe, 70K miles) and it was all gunked up, it runs fine now, none of that stuff going on now
Old Feb 23, 2004 | 04:27 PM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr1775 &raquo;</TD></TR><TR><TD CLASS="quote">ok thanks for the suggestions, yeah it doesnt jump around when it idles, i think im going to try the fuel filter and maybe some injector cleaner, hopefully that will solve the problem, thanks again </TD></TR></TABLE>
or you could use some sea foam . that stuff will clean off all the carbon, varnishes, gunk buildup in your engine. there's a thread I believe in integra forum that's about 8+ pages on sea foam.
Jayrod360
Dec 21, 2012 07:43 PM
CrazyModGSR
Oct 27, 2004 01:24 PM
alfaaay
Mar 9, 2003 01:14 AM
ace1875
13
Feb 8, 2003 12:55 AM
