Amp and dual coil sub match---NEED HELP
Old Jan 30, 2004 | 05:17 PM
brickonwheels's Avatar
Default Amp and dual coil sub match---NEED HELP
If i have an amp that i want to run at 2 ohms, and i am buying a dual coil sub, shouldi get one with 4 ohms resistence or 2? I'm not sure bc of their being two coils and all. Thanks in advace for all of your help.
Chris
Old Jan 30, 2004 | 06:52 PM
ATF Kuk's Avatar
Default Re: Amp and dual coil sub match---NEED HELP (brickonwheels)
get a dual 4ohm sub and wire it parallel, the end result will be 2 ohms
Old Jan 30, 2004 | 09:08 PM
and if i run it like that it will just run as if it were a two channel amp? o and i should clerify, i am getting two subs
Old Jan 31, 2004 | 02:56 AM
vigor5spd's Avatar
Depends on your amp. What kind of amp do you plan on using? What are the specs on it? Some amps have max power at 4ohms others at 2ohms.
Old Jan 31, 2004 | 07:09 AM
This amp has it's max power at 2 ohms
125X2 @ 4ohms, 250X2 @ 2ohms, 500X1 @ 2ohms bridged
Old Jan 31, 2004 | 07:36 PM
Xsi's Avatar
Xsi
Default Re: (brickonwheels)
It looks like your amp is not 1 ohm stable so you should get a 2 ohm DVC.
Running a 4 ohm DVC in parallel will result in a 2 ohm load but you would have to bridge your amp to run it properly resulting in more or less a 1 ohm load which your amp will struggle to handle.
If you buy a 2 ohm amp you can have 2 ohms to each channel which your amp should handle fine.
Old Feb 1, 2004 | 04:05 AM
snoochtodanooch's Avatar
Default Re: (Xsi)
that amp can run at 250 each so just get two DVC 4 ohm subs, wire them seperately to 2 ohms, and wire them to amp each to run in stereo.
Old Feb 1, 2004 | 09:21 AM
turbocivicls's Avatar
Default Re: similar scenario
I have a similar question and I need help as well.... this stuff is so darn confusing..
I have a PPI PCX480 amp and it puts out these specs:
4x80 @ 4ohms
4x150 @ 2ohms
2x320 @ 4ohms
I plan to run it in the bridged mode to get 2x320 to power 2 subs. When I choose a sub that has dual voice coils... there's a choice of either dual 2ohm or dual 4ohm. I'm just going to run 1 sub per channel (each speaker will run 320 watts), so I guess they're not running parallel or series. Which speaker should I choose for this configuration? The dual 2ohm or the dual 4ohm? I'm new at this so I appreciate the help!!
Old Feb 1, 2004 | 09:33 AM
pbcdb's Avatar
Default Re: similar scenario (turbocivicavr)
If I am understanding you question right you should just get 2 single 4 ohm subs.
Old Feb 1, 2004 | 09:44 AM
Default Re: similar scenario (pbcdb)
hmmm... because the speakers I wanted to get have dual voice coils... so I'm not sure if I should get the 2ohm or 4ohm ones.
pityocamptes
Audio / Security / Video
Dec 4, 2017 03:01 AM
Intrepidv614
Dec 13, 2005 05:02 PM
PiNoYxRaCeRxRH88
11
Nov 26, 2005 10:35 AM
woodog
Dec 17, 2001 11:08 PM
GoLowDrew
Jul 17, 2001 09:49 PM
