spun bearing...does your crank mess up easily?
drove the car like 3 times for about a total distance of 2 miles. then i took off the oil pan and realized what happend.
you should jsut get the crank inspected if everything is within spec then you are fine. Else you will have to turn the crank and go one size bigger on the bearings.
