Camber problems after GSR disk brakes UPGRADE? HELP!!!
Old Jan 30, 2004 | 10:06 AM
Kool305's Avatar
Default Camber problems after GSR disk brakes UPGRADE? HELP!!!
I have a 93 EG HATCH and after doing my GSR disk brakes (UPGRADE)
camber problems arised....here are the readings....
*front camber* (right) -4.5
(left) -4.6
(total toe 4.97) has this ever happened to anyone?
the service guy at *TK performance/tire kingdom* said that the main problem
is on the SPINDLE *but how?
I dont get it 92-95/94-2001 integra gsr is the same *****
I used the GSR spindle/full knuckle...(civic) upper control arms
installation was smooth its just the camber problem...before the installation the car had NO camber problems...the guy also said the best camber kit could only correct up to 3.5 or something which leaves me still with some negative camber and said it was not WORTH IT...HELP GUYS...
my final option is to go back to STOCK *DX BRAKES* and get my money back
Old Jan 30, 2004 | 11:11 AM
B18C2_sedan's Avatar
Default Re: Camber problems after GSR disk brakes UPGRADE? HELP!!! (Kool305)
get a camber kit? Yes the fronts are the same spindles are the same. You need a camber kit installed
Old Jan 30, 2004 | 11:14 AM
splitime's Avatar
Is your car seriously dumped low? I have GSR brakes all around and a very mild drop. I also used the civic upper arms, so it looks like we did the exact same thing. I run about -1ish camber on the street because of my drop, no camber kit. Never had to adjust anything other than toe to prevent tire wear.
Old Jan 30, 2004 | 06:35 PM
Kool305's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime &raquo;</TD></TR><TR><TD CLASS="quote">Is your car seriously dumped low? I have GSR brakes all around and a very mild drop. I also used the civic upper arms, so it looks like we did the exact same thing. I run about -1ish camber on the street because of my drop, no camber kit. Never had to adjust anything other than toe to prevent tire wear.</TD></TR></TABLE>
No, its not dumped low it has a mild drop....before the GSR upgrade I used to have the same -1 camber as u do...never had a problem...but the upgrade fawked the whole suspension...
About getting the camber kit... the guy at TK performance adviced that it wasnt WORTH doing due to the drastic camber...i will be going back to DX brakes over the weekend and see what happens...ill keep you guys posted...i cant think of anything else but WRONG BRAKES
Old Feb 1, 2004 | 11:30 AM
Kool305's Avatar
ok...just went back to STOCK DX BRAKES and the problem is fixed....
apparently the guy sold me the WRONG BRAKES and im getting my MONEY back
THE END...
Old Feb 1, 2004 | 11:40 AM
Filliam H. Muffman's Avatar
Default Re: (Kool305)
what a bastard
Creator
Feb 24, 2017 10:25 PM
garyc17
Apr 17, 2008 08:38 AM
doubleshotz
Suspension & Brakes
Nov 2, 2007 05:01 PM
Kool305
Feb 1, 2007 03:35 AM
JrJ93vx
Apr 30, 2003 10:56 AM
