Damage to my R motor...need advice
Old Jan 30, 2004 | 09:14 AM
Rspec CX's Avatar
Default Damage to my R motor...need advice
Well on christmas day I dropped a valve and this is what it did....I need to know if anyone thinks the head can be fixed or if I should just get another or a new one.
Pretty scary looking?
Well here is the bottom end, which I got lucky on and the valve didnt hit the cylinder wall at all.
IB spec Wisecos are on the way....
As far as the head internals go, Toda C's, Toda valve springs, Toda cam gears, Skunk2 retainers, Ferrea valves are all on the way, I just need to know about the damage to this cylinder head.
On a side note Everything that is coming off the head is for sale for REALLY cheap.
PM me offers.
Old Jan 30, 2004 | 09:37 AM
Bbasso's Avatar
Default Re: Damage to my R motor...need advice (Rspec CX)
Looks like the valve seat took a serious beating, I'm thinking that you might not be able to reuse the head.
Any other thoughts?
Old Jan 30, 2004 | 09:38 AM
Bbasso's Avatar
Default Re: Damage to my R motor...need advice (Bbasso)
Can you get a better pic of the seat?
Old Jan 30, 2004 | 09:43 AM
jdmspoonitr's Avatar
That isn't that bad. IMO you are pretty lucky. Good luck with it.
Old Jan 30, 2004 | 10:12 AM
Rspec CX's Avatar
Default Re: Damage to my R motor...need advice (jdmspoonitr)
Any advice on who to contact to find out for sure?
I have a few more pics but I couldnt really get any to show more detail. I will try when I walk out to the garage in a little bit.
Old Jan 30, 2004 | 10:26 AM
GRAVEDIGGER's Avatar
like WHOA
Old Jan 30, 2004 | 10:30 AM
RTW DC2R's Avatar
Ouch. I dont see how that valve seat can be repaired to spec...Im not a machinist though so Im not positive.
Old Jan 30, 2004 | 10:38 AM
Kendall's Avatar
I think you should buy my R motor.
Old Jan 30, 2004 | 12:03 PM
Rspec CX's Avatar
Default Re: (Kendall)
sell me the bare head!
Old Jan 30, 2004 | 12:21 PM
00 FBP ItR's Avatar
email alaniz...w/ pics and all. He'll let you know.
Old Jan 30, 2004 | 01:50 PM
Denny's Avatar
Default Re: (00 FBP ItR)
what causes valves to drop? sorry im a newb
Old Jan 30, 2004 | 01:55 PM
Erik_Pb_Foot's Avatar
New User
Default Re: (Denny)
sounds like an opportunity to upgrade to oversized valves and a 5 angle valve job
if i was in your position i'd send my head off to portflow (or any other reputable shop) and have it tweaked a little. a little work on your combustion chambers would help it breathe better and burn better anyway... and oversized valves will take care of your valve seat problem....
-Erik
Old Jan 30, 2004 | 02:24 PM
non-VTEC's Avatar
i think it can be repaired. the old seat can be pressed out and a new one can be pressed in and machined to look like new.
the other knicks and stuff can be smoothed and polished up if the machine shop who is working on it knows what they are doing........
good luck.
Old Jan 30, 2004 | 02:34 PM
D's Avatar
D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">Looks like the valve seat took a serious beating, I'm thinking that you might not be able to reuse the head.
are you high? DOES ANYBODY ON THIS ******* BOARD KNOW ANYTHING ANYMORE?????????? JESUS!!!!!!!!!!!
Damage is very minimal. any competent auto machine shop should be able to do a minimal ammount of welding to the combustion chamber, install new valve seats, and cut new valve angles.
D
Old Jan 30, 2004 | 03:24 PM
STOLEN - ITR 98-0652's Avatar
Default Re: Damage to my R motor...need advice (D)
Apparently... not.
That's just a little worse than cosmetic.
Old Jan 30, 2004 | 09:25 PM
H-PIMP's Avatar
Default Re: Damage to my R motor...need advice (ITR 98-0652)
I've seen worse repaired.
Old Jan 31, 2004 | 04:41 AM
B17AGSR's Avatar
Default Re: Damage to my R motor...need advice (H-PIMP)
consider yourself lucky, my motor was not salvagable after a valve dropped. take that head to a reputable machine shop to fix it.
SobrietyRulesNA
Feb 4, 2013 10:07 PM
Dee_SydekicK
Jan 19, 2006 07:10 PM
dc800
Feb 3, 2004 01:38 AM
dc800
Feb 1, 2004 11:11 AM
Rspec CX
11
Jan 30, 2004 07:17 PM
