OEM g3 fog wiring in engine bay?
How do I wire the foglights in the engine bay so they work with a switch? I found wiring instructions for the switch, but it has 1 wire going out to the engine bay, and after that im not sure what to do. I have 2 foglights and each one has either a harness plug thing, or 2 wires that would need to be wired.
if you have the OEM kit, you only need one wire running through the firewall to the fog lamps themselves. they are both grounded locally and only need power to draw from the switch to activate.
The team-integra article doesnt say exactly how to do the engine bay wiring, they show a JDM 1 piece headlight/fog wiring. So I just need to ground both of em, and then connect both power wires to the one wire coming from the switch inside the car?
06Accord5SPD
Feb 22, 2016 03:10 PM
