Some pics of my completed engine project
Well it seems like it has taken longer than it actually has but the engine is nearing completion and I thought Id post some pics and get some feedback. Here are the specs.
h22a1
h23 crank
h23 rods w/ arp bolts
h22 type s pistons .25mm oversize
arp head studs
head rebuilt and ported by myself.
stock jdm cams
imagine engineering header
dss stage 2 axles
All going in a 1992 cx. Computer sucks right now so it looks like I'll be adding pics one at a time through editing.
Modified by civicsitek GanGsTa at 12:18 AM 1/30/2004
h22a1
h23 crank
arp head studs
stock jdm cams
dss stage 2 axles
i like it )apperance wise) you will be able tosee leaks easily. but i owuld have done black a different color but with the red on each sid of it it should make it better
same mods as mine, but i used h23 block.... and i painted the block Ford grey. looks good. i also bored the head out myself but made the ports larger. let us know how it goes
Looks good, keep us posted. What kind of CR do you think you have with that setup? Also, looking at the picture, seems like the hone was done with a coarse block. The FRM lining is supposed to be honed with 600 grit stones according to the helm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flyrod »</TD></TR><TR><TD CLASS="quote">Looks good, keep us posted. What kind of CR do you think you have with that setup? Also, looking at the picture, seems like the hone was done with a coarse block. The FRM lining is supposed to be honed with 600 grit stones according to the helm. </TD></TR></TABLE>
i was thinkin the same thing too when i first saw it...other than it kinda reminded me of a jackolantern. Those hone marks look like he used a rougher type of stone.you might have a problem with the rings sealing correctly.
civicsitek GanGsTa
44
Dec 16, 2004 08:02 AM
civicsitek GanGsTa
Oct 19, 2004 04:14 PM
Nikoli
May 15, 2004 11:24 AM
Nikoli
Feb 5, 2004 09:55 PM
