srp je eagle jackson aem h22 crower ls head and cams manifold throttle body ls str
Old Jan 29, 2004 | 07:54 PM
mini-cRx's Avatar
Default srp je eagle jackson aem h22 crower ls head and cams manifold throttle body ls str
je 9:0:1 comp 84.5 mm bore w/rings 500
srp 9:5:1 comp overbore for bseries 500 w/rings
srp 9:0:1 comp .20 over for bseries 450 w /rings
aem cam gears 100 both red like new
eagle rods for ls new 320 shipped
str sheetmetal intake manifold for gsr tapped for direct port intake /manifold is also ported 450 brand new
nos direct port kit bent for b series manifold or str 450new
drt sheetmetal intake manifold for ls 400
75 mm bbk throttle body 250
crower cams street strip for ls 250
crower ls head crower springs vlaves reatiners p&P 425 1000 miles on head
ls cranks blocks
gsr cranks and blocks
jackson supercharger gsr jr boost timing m is like 400 alone fuel pump upgrade puleys belts etc. just missing idler puley
1900 went turbo
89 civic 4dr
engine:
b18b block and head
rebuilt pistons and rings and bearings
integra radiator and new push fans
oil pump
water pump
valve seals
valve cover gasket set
new distrubitur
msd system and coil
missing link
place racing mounts
new axles
new starter
new main seal new axle seals
front mount interccoler
new turbonetics turbot3/t4
new oil lines and new manifold drag
new delta wastegate
new downpipe
new o2
custom crossmember
full exhaust
92-93 gsr tranny with 55,000miles new clutch and pressure plate and throw bearing
runs amazing
interior
autometer gauges all of them
clean interior in mint condition
outside
dropped with prelude rims polished and tints
clean 5000
2003 yamaha blaster 4 yr warranty come take it just take over payments and 100 dollars and its yours 6 hours on it like new
call 2036480261
Old Feb 1, 2004 | 06:41 AM
mini-cRx's Avatar
Default Re: srp je eagle jackson aem h22 crower ls head and cams manifold throttle body ls str (mini-cRx)
ttt
tannerLSt
Jul 12, 2006 05:47 AM
mini-cRx
Mar 17, 2004 06:37 PM
