Do the GSR Moroso oil pan and oil pic up fits to a b20 bottom end?
I want to buy a Moroso but I cannot find a pan for a B20 Vtec engine.
Thanx
Thanx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hovic »</TD></TR><TR><TD CLASS="quote">Do the GSR Moroso oil pan and oil pic up fits to a b20 bottom end?
Thanx</TD></TR></TABLE>
the oil pan wont fit.. from what i remember..
you dont need to change your pickup unless your gonna use the girdle..
and i also remember b20 has the same part number as the itr oil pump
correct me if im wrong
Guest
Posts: n/a
the b16 b18a b18b and b20 motors all share and oil pan and pickup the itr ctr and gsr all use block gridles so the pan and pick up are different for those. the gsr pan not 100% on the moroso setup, but the gsr pan (oem) is compatible with the other b series motors, however the reverse is not true, you can't put the ls pan on the gsr.
