do my dyno numbers look right?
Old Jan 29, 2004 | 02:49 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default do my dyno numbers look right?
dynoed my 190000 mile gsr, i have aem intake, dc sports 4-1 header, and custom 2.25 exhaust to magnaflow muffler. compression check is 240-240-235-245
the dyno was a dynomite dyno. which guy said is around 15% lower then most dynojet dyno's, is this true, how do these numbers compare to others?
152 horse and 103 torque
is this good, i think i am pretty happy with the results seeing how it has the mileage it does
i put this in here seeings how im always in this forum and alot of eg guys have gsr swaps
have bigger pic of graph, just imagestation always makes it smaller
heres link to big version
http://www.we-todd-did-racing....D.jpg
Old Jan 29, 2004 | 02:51 PM
Ricey McRicerton's Avatar
Default Re: do my dyno numbers look right? (coptzer)
Dyno numbers are going to vary from dyno to dyno and elevation to elevation (same with humidity and other factors).
Old Jan 29, 2004 | 03:17 PM
Archidictus's Avatar
Unceasing Measure
If it's USDM, those hp numbers are pretty good...the torque is kinda lacking though.
Old Jan 29, 2004 | 03:18 PM
daver's Avatar
Default Re: do my dyno numbers look right? (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">Dyno numbers are going to vary from dyno to dyno and elevation to elevation (same with humidity and other factors).</TD></TR></TABLE>
Same deal with those high compression #'s. Regardless, the dyno looks good, the link comes out as a blurr for me.
d
Old Jan 29, 2004 | 03:22 PM
todaspecsi's Avatar
Thos look decent. I had a GSR dropped in a 93 civic ex w/ header, exhaust, intake, and msd and dynoed at 158whp and 125lb torque, similar
Old Jan 29, 2004 | 03:27 PM
EJ1_519
Guest
Posts: n/a
Default Re: do my dyno numbers look right? (todaspecsi)
the HP # is good, but torque is
Old Jan 29, 2004 | 04:08 PM
Smith Wise's Avatar
Default Re: do my dyno numbers look right? (EJ1_519)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1_519 &raquo;</TD></TR><TR><TD CLASS="quote">the HP # is good, but torque is </TD></TR></TABLE>
and nice avatar....
well thats what i was thinking, but it is also on a "mustang" type of dyno which usually have 15% difference with dynojet numbers, my torwque curve looks like most others, so im figuring id be putting around 170 hp to the hweels and 120ish torque on a dynojet, or could i be wrong, my a/f ratio is good if you ask me also
Old Jan 29, 2004 | 04:12 PM
SOHC_MShue's Avatar
yea something is wrong with that torque if its not the dyno
Old Jan 29, 2004 | 04:24 PM
fast94ex's Avatar
Default Re: do my dyno numbers look right? (SOHC_MShue)
The hp looks pretty good but i d/k about the torque. I have a jdm b16 in my 94 civic with i/h/e and im, and it put down 155hp 105 tq with timing retard 2 degrees and colder plugs for nitrous.
Old Jan 29, 2004 | 04:32 PM
Default Re: do my dyno numbers look right? (fast94ex)
the usual percentage difference between dynojet and "mustang" type of dynos is between 10 and 15% if i were to multiply mine by that i would get roughly 170 horse and 120 torque, does that sound about right?
Old Jan 29, 2004 | 04:56 PM
fast94ex's Avatar
If you look at percentage that sound right but i dont see it putting down 170 to the wheels like that but you should get 115-120 tq. I have seen a stock type r put down 160hp 122 tq, then he put skunk stage 2 cams and valvetrain and made 195hp 137tq. In perfect weather on a different dyno i would say 160hp 117 tq somewhere around that.
Old Jan 29, 2004 | 05:46 PM
BlueDa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">yea something is wrong with that torque if its not the dyno</TD></TR></TABLE>
Nope its a honda. haha jk
Old Jan 29, 2004 | 08:19 PM
hasback*'s Avatar
F*CK THIEVES!
Default Re: do my dyno numbers look right? (G20Balla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G20Balla &raquo;</TD></TR><TR><TD CLASS="quote">
Nope its a honda. haha jk </TD></TR></TABLE>
lol
Old Jan 29, 2004 | 08:25 PM
hybrider's Avatar
Default Re: do my dyno numbers look right? (hasback_00)
do you have your secondaries wired up?
Old Jan 29, 2004 | 08:54 PM
daver's Avatar
blame the low torque on age or the dyno brand, but the relative hp numbers are impressive. That torque curve just doesn't want to fall off; good header perhaps.
d
Old Jan 29, 2004 | 09:03 PM
Default Re: do my dyno numbers look right? (daver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daver &raquo;</TD></TR><TR><TD CLASS="quote">blame the low torque on age or the dyno brand, but the relative hp numbers are impressive. That torque curve just doesn't want to fall off; good header perhaps.
d</TD></TR></TABLE>
so would a person with a 30,000 mile motor be happy with these numbers, or should i just because the mileage on mine, personally i forgot it was a mustang dyno when we went there and i said id be happy with 150, hell im really happy with 150 now seeings the type of dyno i was on
Old Jan 29, 2004 | 10:21 PM
The Internet Tough Guy's Avatar
looks good to me, especially considering the age. hopefully i'll get that kind of longevity out of this pig sitting here.
Old Jan 30, 2004 | 12:19 PM
Default Re: (jwn7)
BUMP
Old Feb 1, 2004 | 11:37 PM
Default Re: (coptzer)
bump
Old Feb 2, 2004 | 05:15 AM
special ed's Avatar
bump for the avatar
Old Feb 2, 2004 | 07:19 AM
92BlackSi's Avatar
Check my sig you should be considerably higher I would think. Must be the dyno??
hbyrd8701
Apr 5, 2009 06:19 PM
jpenman50
Apr 5, 2006 03:32 AM
megotvtec
Mar 25, 2004 01:24 PM
