wheel is not centered in wheel well
Old Jan 29, 2004 | 02:49 PM
suspendedHatch's Avatar
Default wheel is not centered in wheel well
How do I fix this?! Copy this URL into your address bar, as angelfire does not allow remote images:
http://www.angelfire.com/az3/4...l.jpg
Note that the steering is centered. The wheel is very negatively castered.
I recently installed front and rear LCAs and spindles from a 94+ Integra. This is the only wheel with the problem. None of the parts are visibly bent or installed incorrectly.
Old Jan 29, 2004 | 03:06 PM
untitled's Avatar
Default Re: wheel is not centered in wheel well (shaundrake)
correct me if im wrong but..
something is crooked in the crossmember. thats what dtermines the front to rear movement of the hub i believe.
Old Jan 29, 2004 | 04:51 PM
Sliced Beard's Avatar
Default Re: wheel is not centered in wheel well (Vetter)
dude your lower control arm is bent or your lower crossmember is bent
you really need to get that checked
i am willing to bet money that you have either a bent crossmember or lower control arm
Old Jan 30, 2004 | 09:30 AM
PupaScoopa's Avatar
Default Re: wheel is not centered in wheel well (dirtyd463)
Mine's the same, it's bent.
sicksiguy
10
Jun 3, 2016 01:46 AM
whyS0serious
16
Jun 27, 2010 02:27 PM
SexyEJ8
Jul 6, 2008 07:32 AM
Spike_irl
May 12, 2005 06:39 AM
90H22
Jan 28, 2003 09:47 AM
