O2 sensor; before or after the turbo?
hey i have got most of my stuff together for my turbo swap.... i see most cars have the o2 sensor after the turbo but does this matter at all? see im using a HF manifold and a adapter to the turbo.... the down pipe will have to be custom made do it would be good to know if i need to plug the hole on top or what... maybe i will run my exh. temp sensor from there? thanx
no problem, another thing put the egt about 1-2 inches away from the head, and the o2 sensor im not sure but i have seen them about 3 inches away from the turbine outlet on the dp
