1992 Accord Failed Emission
Old Jan 29, 2004 | 11:55 AM
abeaujuin's Avatar
Default 1992 Accord Failed Emission
The following failed the Georgia Emissions:
HC-ppm Reading (0148) Allowable (132) - 50/15 TEST
CO-% Reading (0.10) Allowable (0.73) - 50/15 TEST
Any suggestions of fixes for these?
Old Jan 29, 2004 | 12:24 PM
fw190bvi's Avatar
Default Re: 1992 Accord Failed Emission (abeaujuin)
move to michigan.....no emisions test, and once a car is 10 yrs old, its void from state emission/noise level laws
Old Jan 29, 2004 | 09:59 PM
raceACCORDingly's Avatar
https://honda-tech.com/zerothread?id=313708
Old Jan 29, 2004 | 11:19 PM
Oh Crap's Avatar
I recommend GTP gaurenteed to Pass.. some gasoline additive.. i recommend that to all of our customers who don't fail by much.
Old Feb 5, 2004 | 10:03 PM
Qfactor's Avatar
Default Re: 1992 Accord Failed Emission (fw190bvi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi &raquo;</TD></TR><TR><TD CLASS="quote">move to michigan.....no emisions test, and once a car is 10 yrs old, its void from state emission/noise level laws</TD></TR></TABLE>
damn, you lucky dogs!!! thats sweet. here in california is 30 yrs!!
Old Feb 5, 2004 | 10:39 PM
BigLoadChoakHard's Avatar
i would recomend you check the timing and as an easy start check the computer with a scan tool for a lazy or malfunctioning o2s and overly rich mixture will cause high hydro carbons something simple disconnect a small vacuum line
Old Feb 6, 2004 | 10:19 AM
m0t0rhead's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abeaujuin &raquo;</TD></TR><TR><TD CLASS="quote">The following failed the Georgia Emissions:
Any suggestions of fixes for these?</TD></TR></TABLE>
If you haven't done much along the lines of maintenance... a simple tune-up should get you passed.
Plugs, Wires, Cap, Rotor, Air Filter and Fuel Filter. An intake/injection service would be a good idea also. Try the BG Fuel Injection Service. Simply amazing.
http://www.bgprod.com/
Old Feb 6, 2004 | 11:50 AM
lhd dc2's Avatar
My car had failed horribly in those areas. And I did was add Guaranteed to Pass stuff in the tank and run it. And I passed. Good stuff. Hope that helps.
Im also in GA so I kno how that emissions stuff goes.. good luck
Old Feb 6, 2004 | 06:58 PM
m0t0rhead's Avatar
Default Re: (single cam)
If it's failing emissions.. that means it's not running as well as it should be. Just spend the money and keep it maintained.. and you won't have to worry about "band-aids" like that **** he was talking about.
Old Feb 7, 2004 | 12:48 PM
lhd dc2's Avatar
some people dont have the money to fix it right away. And some people have to get the emissions out of the way to get their car out on the road again. Doesnt hurt putting GTP in it, to just pass emissions. Regardless if its a "band aid" cure. The "****" works.
And later you could do the basic tune up. Because thats what ANY car needs.
Old Feb 7, 2004 | 01:41 PM
a tune up isnt gonna fix the problem unless the motor has a misfire
Old Feb 9, 2004 | 09:42 AM
m0t0rhead's Avatar
Default Re: 1992 Accord Failed Emission (BigLoadChoakHard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigLoadChoakHard &raquo;</TD></TR><TR><TD CLASS="quote">a tune up isnt gonna fix the problem unless the motor has a misfire </TD></TR></TABLE>
Don't make posts like this that aren't factual.
A tune-up consists of : plugs, wires, cap, rotor, fuel filter and fuel injection service. If he has no "check engine light" then there isn't a malfunction in any of his working parts. The only other thing that would cause problems with emmisions would be a clogged EGR valve and port. Even that would throw a code. 9x out of 10 a simple tune-up will solve his problem.
Old Feb 9, 2004 | 10:06 AM
RotaryBzzzz's Avatar
Default Re: 1992 Accord Failed Emission (Escobar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Escobar &raquo;</TD></TR><TR><TD CLASS="quote">
A tune-up consists of : plugs, wires, cap, rotor, fuel filter and fuel injection service. If he has no "check engine light" then there isn't a malfunction in any of his working parts. The only other thing that would cause problems with emmisions would be a clogged EGR valve and port. Even that would throw a code. 9x out of 10 a simple tune-up will solve his problem. </TD></TR></TABLE>
100% Yup. And don't forget to change the oil. 1000+ on oil can radically change your emissions.
Green is good. If anything, you'll have more power and better gas mileage.
oil + filter. $2.5 + 4 = $6.50
plugs. $6.50 (4)
STP injector cleaner. $2.50
new air filter. $15
total = ~$30
Old Feb 9, 2004 | 02:12 PM
lhd dc2's Avatar
piggydog
May 16, 2006 07:32 PM
cycledick
Oct 9, 2004 10:50 AM
taniaml
Jul 28, 2004 10:45 AM
SIK IN DA HED
Jul 9, 2004 01:30 PM
Ideal
Aug 19, 2002 04:29 PM
