tranny problem 88 prelude
Old Jan 29, 2004 | 10:40 AM
brokencam's Avatar
Default tranny problem 88 prelude
Hello. I have a tranny/clutch problem. It will not go into gear while started, but
it will when not started. I have seen a post here where someone had about the same problem .. I put it in 3rd gear
and drove it all the way homeand it didnt stall one time. I wasted $60 on a slave cylinder and it did nothing. I need help i am tired of driving this loaner. Try picking up a chick in 91 buick skylark. with a nonworking driverside
window......
Any help would be great..
thanx
EDDIE
Modified by brokencam at 7:54 PM 1/29/2004
Old Jan 29, 2004 | 10:46 AM
Sephro's Avatar
Default Re: tranny problem 88 prelude (brokencam)
sounds like you need a new clutch... So if you have the car off and you put it into gear... start the car it will stay in one place like it won't roll when your cranking it?? Also if you clutch in can you idle in gear??
Old Jan 29, 2004 | 10:53 AM
brokencam's Avatar
it rolls. My friend posted that for me..
Old Jan 29, 2004 | 10:57 AM
brokencam's Avatar
when i turn the car on in gear i can smell the clutch burning
Old Jan 29, 2004 | 11:59 AM
Daily Interlude's Avatar
Still have clutch pedal pressure? Sounds like clutch.
Old Jan 29, 2004 | 12:13 PM
Sephro's Avatar
Default Re: (Daily Interlude)
You need a new clutch.... either is't worn out or it's broken. I bet you find a broken/missing spring in the disk when you pull it.
Old Jan 29, 2004 | 06:56 PM
H22A EG6's Avatar
Default Re: (Sephro)
that bad boy is shot
Old Jan 30, 2004 | 10:18 AM
kablamo's Avatar
Default Re: (H22A EG6)
yeah clutch sounds like a culprit but did you ever check the master cylinder?
if you change the clutch but the master cylinder is gone, it's going to be big trouble again for you. a new slave wouldn't help either (if it really was the master cylinder).
they're pretty cheap (>100$) and fairly easy to change too
turbojohnny
Sep 30, 2009 09:18 AM
jdmej2lolo
Oct 17, 2008 09:13 AM
TKL
14
Nov 11, 2004 09:27 AM
elips0id
Apr 1, 2004 03:38 PM
tilt
Oct 7, 2002 01:22 PM
