rear motor mount inserts - installatioin (again)..... prothane this time!
Old Jan 29, 2004 | 10:35 AM
Black R's Avatar
25 Year Member
Default rear motor mount inserts - installation (again)..... prothane this time!
What's the easy way to do it?
The last two times I installed ES rear motor mount inserts. It was just a matter of taking 2hrs to squeeze them in between towards the mount. They are softer than the prothane ones.
This time, I want to be in and out as quickly as possible. I'm also going to replace the mount AND install the prothane inserts into the new one.
Tips please?
I need an easy way, since I've done it the hard way already too many times.....
Old Jan 29, 2004 | 10:39 AM
baonest's Avatar
Default Re: rear motor mount inserts - installation (again)..... prothane this time! (Black R)
you gonna have to use a jack and jack the rear of the motor i beleive(or maybe it was the side mounts, hell i forgot).. i was lucky when i installed mine, the motor was out of the car.
but im sure lots of people on here have done it.
Old Jan 29, 2004 | 10:55 AM
AssPenny's Avatar
Default Re: rear motor mount inserts - installation (baonest)
Remove the rear mount/bracket all together?
Old Jan 29, 2004 | 10:59 AM
Reid's Avatar
Global Moderator
I would remove the two front/lower motor mounts, and try to tilt the motor forward to help gain access to the rear motor mount.
Old Jan 29, 2004 | 11:03 AM
mstewar's Avatar
Default Re: rear motor mount inserts - installation (Reid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">I would remove the two front/lower motor mounts, and try to tilt the motor forward to help gain access to the rear motor mount. </TD></TR></TABLE>
yep.. this is the easiest way.. is still a PIA though..
Old Jan 29, 2004 | 11:06 AM
TypeR 599's Avatar
What I did was remove the lower driver side and loosened the upper driver side mount. support the motor with a jack under the pan( my pan is perfectly fine, no dents or anything, just distribute the contact point with a 2x4). remove all the bolts holding the "T" bracket, the bracket should be able to separate(split down the middle). then unbolt the 3 bolts holding the actual mount and it should come out.
Old Jan 29, 2004 | 09:28 PM
Black R's Avatar
25 Year Member
Default Re: rear motor mount inserts - installation (TypeR 599)
I did the "tilt the motor forward" method the last two times.
Oh well, I guess the 3rd time's the charm.....
Old Jan 29, 2004 | 11:14 PM
MR5sARECOOL's Avatar
Default Re: rear motor mount inserts - installation (Black R)
i had to unbolt the lower fronts, and i think the dr side. jack it up, and unbolt part of the back mount from the block as well as from the mount, and they slipped in. but its been a while
Old Jan 30, 2004 | 01:04 AM
ALLMOTOR18's Avatar
you can also loose one of the side mounts to allow the motor to move more.. just make sure you have a jack under there to support the motor..
Old Jan 30, 2004 | 05:44 AM
PM-Performance's Avatar
Default Re: rear motor mount inserts - installation (mstewar)
goosd luck , unfortunately there is no easy way. that6 back mount is even a pain in the *** getting the motor back in the car 1/2 the time .
Old Jan 30, 2004 | 10:42 AM
B18CXr's Avatar
Tips please?
should take around 45mins for all three mounts.. less for non DC-2R chassis
Old Jan 30, 2004 | 11:14 AM
Doctor CorteZ's Avatar
Default Re: rear motor mount inserts - installation (B18CXr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr &raquo;</TD></TR><TR><TD CLASS="quote">[I]less for non DC-2R chassis</TD></TR></TABLE>
unless its a Minivan
Old Jan 30, 2004 | 12:45 PM
Mr Furball's Avatar
Default Re: rear motor mount inserts - installation (Doctor CorteZ)
or a CRX hybrid.
Old Jan 31, 2004 | 07:34 AM
Black R's Avatar
25 Year Member
should take around 45mins for all three mounts.. less for non DC-2R chassis</TD></TR></TABLE>
.....I already have the inserts in the other 4 mounts (upper and lower). ES lower (including the rear) and Prothane upper. Now I simply want to swap the ES inserts in the rear mount with the Prothane ones. AND I'm swapping the rear motor mount as well (since I have a low low LOW mileage one here). Capish? (sp?)
I guess I will do as I have done twice in the past and loosen the upper mounts + remove the lower mounts, and jack up the motor + tilt it forward.....
airikkCRX
Jul 27, 2008 07:52 AM
onyx00
Sep 24, 2004 01:00 PM
Kato7997
Mar 4, 2003 06:03 PM
TeamFlip02
Sep 12, 2002 07:49 AM
KF_S2000
Apr 1, 2002 07:13 PM
