Calling all Hondata Intake gasket owners
Old Jan 29, 2004 | 10:21 AM
B18C2_sedan's Avatar
Default Calling all Hondata Intake gasket owners
I was searching Honda-tech as always and come across a post about Hondata Intake manifold Gaskets. After reading what hondata claims,( example dyno chart) I want to hear what fellow HT members think about it. I already have a skunk2 man installed so I searched and found that longer head studs would be a must. Should I believe the hype?
Old Jan 29, 2004 | 10:28 AM
Spade's Avatar
Default Re: Calling all Hondata Intake gasket owners (B18C2_sedan)
How would you increase the length of the intake manifold studs?
I like my Honda OEM gasket. It seemed to insulate quite well compaired to two different aftermarket gaskets.
AND it was 5 dollars!
Old Jan 29, 2004 | 10:39 AM
Default Re: Calling all Hondata Intake gasket owners (Spade)
I was going to change out the 8x25 gsr intake studs with 8x40
Honda part 92900-08040-1B. A hondata is re useable and keeps intake temps down. At least that's what the website said. I'm just trying to find out from people that know the truth.
Old Jan 29, 2004 | 11:04 AM
T.J.'s Avatar
I have one and yes the intake manifold does feel a bit cooler after running the car for a while but i don't how much its really helping me. My main reason for having it is just being able to reuse it.
Old Jan 29, 2004 | 11:10 AM
tz-devil77's Avatar
Default Re: Calling all Hondata Intake gasket owners (Skunk2whore)
i have made a similar gasket to hondatas, it keeps the intake cooler than the hondata did on my friends car. There is a difference!!!!!!!! I have reused my gasket 5 times.
Old Jan 29, 2004 | 11:20 AM
kKdARIAN's Avatar
Vice President/CEO
Default Re: Calling all Hondata Intake gasket owners (tz-devil77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tz-devil77 &raquo;</TD></TR><TR><TD CLASS="quote">i have made a similar gasket to hondatas, it keeps the intake cooler than the hondata did on my friends car. There is a difference!!!!!!!! I have reused my gasket 5 times.</TD></TR></TABLE>
Care to share the info of this magical better then hondata gasket?
Old Jan 29, 2004 | 12:17 PM
Matty.'s Avatar
Skunk2 - did you use the longer manifold stud that B18C2-sedan listed with yours?
Just curious cuz I have taken off my manifold enough times to warrant the $ tag.
Old Jan 29, 2004 | 12:23 PM
Nextelbuddy's Avatar
Default Re: Calling all Hondata Intake gasket owners (gumtape_deathmatch)
i got one when i put my edlebrock intake manifold on. there definately is a difference in manifold temp. after running my car hard i can still tough the intaske manifold and ym motor is turbocharged. before i couldnt do that.
Old Jan 29, 2004 | 12:33 PM
Default Re: Calling all Hondata Intake gasket owners (nextelbuddy)
I've seen better times at the track by icing down the intake. Cooler is better on the intake side of the house. That is a proven fact.
Well I think it time to fork out some money for a hondata gasket.
Old Jan 29, 2004 | 12:57 PM
tz-devil77's Avatar
Default Re: Calling all Hondata Intake gasket owners (kKdARIAN)
it is jsut main out of polyphenelic material, a little thicker, i do reccomend replacing the studs. i didnt hve to on mine but i did on a friends,we both have skunk2 manifolds.
Old Jan 29, 2004 | 01:05 PM
Eee Pee's Avatar
I have one on my D16Z6 Autocross car. I have the stock IM.
I also use the Iceman headlight ram air piece.
The sole purpose of these two pieces for me was to supply the engine with the coldest air I could.
Seeing how every little bit helps, I figured I'd start with cold air.
The IM has been measured with a pyrometer 30* cooler than the head, two inches away from each other.
Whether it was after the first run, or last run.
Old Jan 29, 2004 | 01:11 PM
HNDAPWR's Avatar
Default Re: Calling all Hondata Intake gasket owners (Eee Pee)
Best 60 dollar mod ive done. I didn't extend the studs. There is definatly a noticable temp. difference esp. with the JRSC. Well worth the moneyin my opinion.
Old Jan 29, 2004 | 03:02 PM
Default Re: Calling all Hondata Intake gasket owners (HNDAPWR)
word
Old Jan 29, 2004 | 04:10 PM
GPoodle
Guest
Posts: n/a
Yeah get it.
Before I had mine, I couldnt touch the IM after driving for a while, now you could put your **** on it.
Old Jan 29, 2004 | 05:02 PM
sirjeff's Avatar
Default Re: Calling all Hondata Intake gasket owners (GPoodle)
you could.....or.............
Old Mar 7, 2004 | 11:17 PM
DSRxCandyh2bEG's Avatar
In the directions it says to reroute the coolant lints that go from your motor/ thermostat, to the iac, to the throttle body, and back to the motor or thermostat housing. (depends on what motor you have, i have a h22a) basically it says to go from the thermo housing to the iac and back from the iac to the thermo housing. Honestly, i think that is the real reason why this gasket works, cause there isnt hot coolan being past by the throttle body anymore... just what i think... i have it only cause its reusable... 5 times 15 bux is more than 60 dollars so it pays for itself...
grenthang
26
Dec 2, 2004 07:12 PM
PrecisionH23a
Sep 19, 2004 07:38 PM
b16vtecsol
27
Dec 16, 2003 12:11 PM
douglas_be
Dec 2, 2003 01:04 PM
MK Ultra
Nov 7, 2002 01:04 PM
