Help!??! Zex kit in a H22 4gen Accord
I am puttin in a zex kit in my H22 93 4 door honda accord. I was wondering what i would need or if there are anytips for the install. I already have the zex purge kit, and msd ignition and plugs, and was wondering if there were any odds and ends that i would need to complete the install. Also is a 75 shot ok for the block. I know that a gs-r block can take a 100 shot, so im assuming that a 75 shot is ok for the h22. please any info or help would greatly appreciated. thanks
Pick up a fuel pump and FPR if you want to be very safe. Can you retard the timing with the MSD that you have? Retarding the timing will be necessary for a 75 shot. Also if you have a 97+ H22a engine NOS makes a plate kit for you, and it gives much better distribution than the ZEX dry kit. Even distribution means that you won't run lean in one cylinder b/c it's getting more nitrous than the other 3. Another option is to run an 80 shot direct port, which is what I'll be doing next season. Also get a good A/F gauge, fuel pressure gauge, NOS pressure gauge and some NGK plugs and wires. superhonda.org has a good NOS board if you have some more questions. Wutangben and dubster99 both know there nitrous over there.
