s2000 oil filter
Old Jan 29, 2004 | 05:59 AM
020's Avatar
020
that's no moon
Default s2000 oil filter
Ok i did a search and i know this has been discussed before. Doesnt an s2000 oil filter fit a F23A1. Also is the drain plug in an s2000 magnetic? Does it fit?
Old Jan 29, 2004 | 07:10 AM
MrBui's Avatar
Default Re: s2000 oil filter (icedmocha)
most hondas will use the filter...15400-pcx-004 is the part number but im sure u can use the 15400-plm-a02 filters
Old Jan 29, 2004 | 11:33 AM
::MYCORD::'s Avatar
Yes the S2000 filter fits, that's what I have on my car.
Old Jan 29, 2004 | 12:56 PM
Beach Accord's Avatar
Default Re: s2000 oil filter (mycord)
i only use the s2000 filters on my f23
also i use the discontinued 15400-POH's
any honda filter made by toyo roki is for me!!!!
Old Jan 29, 2004 | 02:09 PM
Legendaryyaj's Avatar
Default Re: s2000 oil filter (Beach Accord)
Why does everyone use the S2k filter, does it give you more power when compared to the Accord one? Isn't a OEM Honda filter just a OEM Honda filter, all built with same qaulity? Or is it that the S2k filter filters out better.
Old Jan 29, 2004 | 02:59 PM
::MYCORD::'s Avatar
Default Re: s2000 oil filter (Legendaryyaj)
The S2000 filter doesn't give u more power or anything. It just helps protect the engine better. Honda used three different manufacturers for their oil filters. (well now only two since the USA made Filtech oil filter is no longer made) The manufacturers were Fram, Filtech and Toyo Roki. As many know, the Fram filter is crap with its cardboard endcaps. Unfortunately, the fram filter is the most common of these three. The new fram filters look a little better but I still wouldn't use the new ones. The filtech filter was a pretty good filter. I used it before i switched to the S2000 filter. Now... the Toyo Roki filter (S2000 filter) was only available in Japan. BUT now they brought it here in the form of the S2000 filter. This filter is far better in quality then both filters. So quality wise, the S2000 filter is the best.
Sparknotes: The other Honda filters don't have a chance when it comes to quality with the S2000 Toyo Roki filter.
Old Jan 29, 2004 | 07:12 PM
DIYaccord's Avatar
what about f22b2? will it fit that?
how much are they?
Old Jan 29, 2004 | 07:49 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mycord &raquo;</TD></TR><TR><TD CLASS="quote">The S2000 filter doesn't give u more power or anything. It just helps protect the engine better. Honda used three different manufacturers for their oil filters. (well now only two since the USA made Filtech oil filter is no longer made) The manufacturers were Fram, Filtech and Toyo Roki. As many know, the Fram filter is crap with its cardboard endcaps. Unfortunately, the fram filter is the most common of these three. The new fram filters look a little better but I still wouldn't use the new ones. The filtech filter was a pretty good filter. I used it before i switched to the S2000 filter. Now... the Toyo Roki filter (S2000 filter) was only available in Japan. BUT now they brought it here in the form of the S2000 filter. This filter is far better in quality then both filters. So quality wise, the S2000 filter is the best.
Sparknotes: The other Honda filters don't have a chance when it comes to quality with the S2000 Toyo Roki filter.</TD></TR></TABLE>
What about the K&N ones, ive been using those with Royal Purple.
Old Jan 29, 2004 | 07:59 PM
SOHCArchangel's Avatar
k&n HP-1005
Old Jan 29, 2004 | 08:11 PM
::MYCORD::'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Legendaryyaj &raquo;</TD></TR><TR><TD CLASS="quote">
What about the K&N ones, ive been using those with Royal Purple.</TD></TR></TABLE>
The K&N ones are good too but at 10 bucks a pop, I don't know if I will spend that much on an oil filter. The S2000 filters i buy are only 6 bucks.
Old Jan 29, 2004 | 09:36 PM
Accord94DX's Avatar
15400PLMA02 = crap
S2000 filter is the ****. It works on A, B, C, D, F, J series engines
Old Jan 30, 2004 | 12:36 AM
hondaboii's Avatar
where would you be able to find some of those S2000 filters? Thank you in advance...
Old Jan 30, 2004 | 05:43 AM
Accord94DX's Avatar
Default Re: (hondaboii)
honda
Old Jan 30, 2004 | 05:52 AM
Hondaaccordvtec's Avatar
Default Re: (Accord94DX)
IF it works on F-seies motors, is it safe to say that it also works on H-series motors?
Old Jan 30, 2004 | 05:56 AM
Accord94DX's Avatar
Default Re: (Hondaaccordvtec)
yeah basically every honda engine except for the hybrids
Old Jan 30, 2004 | 06:51 AM
SOHCMAN's Avatar
so basically, you just go to your honda dealership and ask for a few s2000 filters?? Dont all of them cost like 6 bucks at honda? If this is true, Ill kick myself for always asking for an accord filter
sohc
Old Jan 30, 2004 | 07:52 AM
jweller's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mycord &raquo;</TD></TR><TR><TD CLASS="quote"> Honda used three different manufacturers for their oil filters. (well now only two since the USA made Filtech oil filter is no longer made) </TD></TR></TABLE>
I bought the new style small filters a month or so ago, and they are made by filtech. Don't know how this rumor got started, but it doesn't seem to be true.
Old Jan 30, 2004 | 08:45 AM
Default Re: s2000 oil filter (jweller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jweller &raquo;</TD></TR><TR><TD CLASS="quote">
I bought the new style small filters a month or so ago, and they are made by filtech. Don't know how this rumor got started, but it doesn't seem to be true.</TD></TR></TABLE>
well the filtech filters you are getting from the dealer are just the overstock and they are selling them until they are gone.
in which case they will then be using the plm-ao2 (fram)
the plm-a01's (filtech) are no longer being produced however the dealers that still have some left are selling them you see?
Old Jan 30, 2004 | 10:05 AM
LX4CYL's Avatar
so are these new Honda oil filters any good?
http://www.hparts.com/cgi-bin/...44623
Old Jan 30, 2004 | 10:50 AM
DrunkNRacer's Avatar
Default Re: s2000 oil filter (LX4CYL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LX4CYL &raquo;</TD></TR><TR><TD CLASS="quote">so are these new Honda oil filters any good?
http://www.hparts.com/cgi-bin/...44623</TD></TR></TABLE>
Wow! $4 ! I pay over $8 at local dealerships.. that sucks.
Old Jan 30, 2004 | 11:10 AM
LX4CYL's Avatar
Default Re: s2000 oil filter (DrunkNRacer)
yeah, they sell Honda ATF-Z1 for $2.83/quart, unlike the dealer, which charges more than twice the price
Old Jan 30, 2004 | 01:08 PM
on that website, i cant seem to find a part number for the oil filter shown.
because
644623
and
490818
arent part numbers
they always start with 15400-xxx-xxx
Old Jan 30, 2004 | 01:13 PM
LX4CYL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Beach Accord &raquo;</TD></TR><TR><TD CLASS="quote">on that website, i cant seem to find a part number for the oil filter shown.
because
644623
and
490818
arent part numbers
they always start with 15400-xxx-xxx</TD></TR></TABLE>
yeah, I think you're right
here's the list:
http://www.hparts.com/sale.php3
and here's another site which shows the correct part numbers:
http://www.handa-accessories.com/accmaint01.html
Old Jan 30, 2004 | 02:56 PM
RotaryBzzzz's Avatar
wow that stuff is much cheaper. I wonder how much shipping is? Anyone have any shipping experience?
Old Jan 31, 2004 | 09:37 AM
020's Avatar
020
that's no moon
Default Re: s2000 oil filter (RotaryBzzzz)
I just taken for eight dollars and change for the PHX-004 today!
coot_er
May 28, 2008 04:46 PM
jinu
Jan 13, 2008 10:54 AM
rohec04
Aug 7, 2007 10:11 AM
Mr.Speed
Jun 1, 2005 06:11 PM
