ITR(96) engine in EG, which harness?
Old Jan 29, 2004 | 05:21 AM
ENDLESS9's Avatar
Default ITR(96) engine in EG, which harness?
I just discovered that some of the engine harness has been burned and/or start breaking off. This must be the cause of the minor fire incident we had during the 25 hour enduro race in December at Thunderhill. Could anyone tell me which engine harness I need to buy to repair this damage?
Our car is 92-95 EG + 96 JDM ITR engine.
The damage has been done to the harness in engine but I would like to change all the harness (engine and inside) if you guys can provide me good information about this.
Thanks for your time and understanding.
Old Jan 29, 2004 | 06:47 AM
sleeperek's Avatar
Default Re: ITR(96) engine in EG, which harness? (ENDLESS 9)
If your running an ODB 1 ECu then just use a ODB 1 GSR harness...
Old Jan 29, 2004 | 08:31 AM
ENDLESS9's Avatar
Default Re: ITR(96) engine in EG, which harness? (sleeperek)
Thank you for the information.
My friend may have the harness for Del sol vtec, would it work if it is for OBD 1?
Old Jan 29, 2004 | 08:39 AM
sleeperek's Avatar
yeah it'll work....
Old Jan 29, 2004 | 08:40 AM
redlinetuning's Avatar
yes... basically any OBD1 VTEC harness will work.. good luck.
EDIT: damn.. sleeperek.. you beat me to it again.
Old Jan 29, 2004 | 09:28 AM
ENDLESS9's Avatar
Thanks again.
Old Jan 29, 2004 | 09:05 PM
Bonez21's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ENDLESS 9 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks again.</TD></TR></TABLE>
yea basically have the same setup wit 97 R using 92-95 si harness
Old Jan 30, 2004 | 07:21 PM
salbaje's Avatar
you can use any 92-95 vtec harness's and 96-up harness's. Which alternator, dist, injectors are you using??
Old Feb 4, 2004 | 09:38 PM
Bonez21's Avatar
i'm running a 99 obd2 gsr harness with my obd2 R alternator but all off a chipped P28
ENDLESS9
May 5, 2014 08:43 PM
zdiddy22
Oct 14, 2013 08:51 AM
boostedb20z
Jul 23, 2009 08:13 PM
avaldez
21
Jun 24, 2009 09:15 AM
lazy bum shaughn
Nov 27, 2003 08:29 PM
