how many bars?
Old Jan 29, 2004 | 02:49 AM
2lua's Avatar
Default how many bars?
how many tie, strut, sway bar do you guys have on your car? how many do you guys think that you car should have?
Old Jan 29, 2004 | 02:58 AM
ATS*Mark's Avatar
OG triple OG
Default Re: how many bars? (2lua)
well , i have alot
spoon front upper strut bar
spoon rear upper strut bar
spoon front lower tie bar
benen rear lower tie bar
jdm itr 23mm rear sway bar
tas C pillar bar
j's racing c pillar bar modified as a cross brace(em racing copied me)
benen strong bar
autopower 4 point street cage
soon to be area 51 harness bar
i have 9 right now
Old Jan 29, 2004 | 03:22 AM
E-brake or Handbrake's Avatar
Default Re: how many bars? (Hella_JDM)
Nine...
i think you might have half of a roll cage in your car.
Old Jan 29, 2004 | 03:33 AM
2lua's Avatar
holly smoke....
Old Jan 29, 2004 | 04:50 AM
ATS*Mark's Avatar
OG triple OG
Default Re: how many bars? (EJ1Z6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1Z6 &raquo;</TD></TR><TR><TD CLASS="quote">Nine...
i think you might have half of a roll cage in your car.</TD></TR></TABLE>
i have a roll cage , that counts as one bar
Old Jan 29, 2004 | 04:51 AM
B18C5-EH2's Avatar
Former Moderator
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lua &raquo;</TD></TR><TR><TD CLASS="quote">how many tie, strut, sway bar do you guys have on your car? how many do you guys think that you car should have? </TD></TR></TABLE>
I have no strut bars on my car.
Good struts, springs, tires, and SWAYBARS add shitloads better handling over strut bars.
If you've already got good struts/springs, swaybars, good tires, etc. then the strut bars can help, but stand alone they do little.
Old Jan 29, 2004 | 04:55 AM
Targa250R's Avatar
be professional
Zero and zero.
Old Jan 29, 2004 | 05:04 AM
Silverhatch's Avatar
we wanna see some pics
Old Jan 29, 2004 | 05:05 AM
Viva la Nubz's Avatar
neuspeed upper front
cusco front lower tie
cusco rear lower tie
cusco upper rear strut
getting trunk bar and sways sometime.
Old Jan 29, 2004 | 05:06 AM
ATS*Mark's Avatar
OG triple OG
Default Re: how many bars? (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">
If you've already got good struts/springs, swaybars, good tires, etc. then the strut bars can help, but stand alone they do little.</TD></TR></TABLE>
true and true.... i have tein flex's which are very sexual . but if there is a bar or device that helps my car handle better i will own it
still on the list
area 51 b pillar harness bar
do luck room bar
benen unreleased under strut bar strut bar
fender braces
Old Jan 29, 2004 | 05:20 AM
foz's Avatar
foz
SKunk2 Front upper
Skunk2 Rear upper
Skunk2 Rear lower tie
I put the rear upper on first and felt a slight difference
a week later put the front upper on and felt a big difference
another week went by and I put the rear lower on and felt a difference
I don't think they were all necessary, but I like the way it rides, the only one I would remove if any is the rear upper, takes up trunk space (but looks cool)
Old Jan 29, 2004 | 05:39 AM
Jon D's Avatar
Welp.......lets see!!!
Type R front strut bar
DC Sports lower tie bar
.....and thats it!!!!
B18C5-EH2 is right....get a good set of springs/struts and tires and some sways and youll be fine.
Old Jan 29, 2004 | 05:51 AM
CivHizzle's Avatar
i just have an ebay strut bar in the engine bay and an srr tie bar in the rear... i need to get a rear upper strut bar
Old Jan 29, 2004 | 07:02 AM
SloCivicHMM's Avatar
Default Re: (CivHizzle)
OEM 99-00 Si strut bar up front
OEM GSR Upper Tie bar
OEM 24mm GSR front swa
OEM ITR rear strut bar
DIY Trunk/Hatch bar
Progress 22mm rear sway
Old Jan 29, 2004 | 03:23 PM
ATS*Mark's Avatar
OG triple OG
Default Re: how many bars? (B18C-Rsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C-Rsi &raquo;</TD></TR><TR><TD CLASS="quote">Welp.......lets see!!!
B18C5-EH2 is right....get a good set of springs/struts and tires and some sways and youll be fine. </TD></TR></TABLE>
yes , but when you have a very nice set of dampers and tires and whatnot , strut bars will help as well ,fo sho wont hurt
but a good set of dampers and a nice rear sway bar will be the biggist difference hands down.....
Old Jan 29, 2004 | 03:25 PM
sleepyEK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">well , i have alot
tas C pillar bar
benen strong bar
i have 9 right now</TD></TR></TABLE>
also doubles as a jungle gym for the wee ones.
Old Jan 29, 2004 | 03:27 PM
ATS*Mark's Avatar
OG triple OG
Default Re: how many bars? (sleepyEK)
ahahaah
my number one wish , is someday my dampa-chi will come alive , and start running around the inside of my car and climb on my bars and ****
Old Jan 29, 2004 | 03:31 PM
Archidictus's Avatar
Unceasing Measure
1993 Si
OEM front swaybar
Rear ebay lower tiebar
Rear Suspension Techniques swaybar
Works like a charm. KISS, baby.
Old Jan 29, 2004 | 03:32 PM
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">ahahaah
my number one wish , is someday my dampa-chi will come alive , and start running around the inside of my car and climb on my bars and ****</TD></TR></TABLE>
It's just two hits of acid away .
Old Jan 29, 2004 | 03:45 PM
ATS*Mark's Avatar
OG triple OG
Default Re: how many bars? (Archidictus)
ahahaha i know other dampa chi owners feel the same!!!! heheeh damn that would be off the hook
Old Jan 29, 2004 | 03:51 PM
Fowler.'s Avatar
A.
1997 Cx
JDM ITR motor w/ LSD
CTR 26mm front bar
JDM ITR 23mm rear bar
stock shocks
stock 14" wheels/tires
B.
1997 Cx
stock motor
Tein RA full coilovers
15x6.5 wheels with shitto tires.
To me, A was 10x more stable than B. I think sway bars completely make the difference. Strut bars are more show than anything else. I mean, yeah, they offer something, but swaybars are waaaaayyyy more useful.
Old Jan 29, 2004 | 04:01 PM
GPoodle
Guest
Posts: n/a
front upper strut bar, no upper in the back due to sub box ... Lower tie bar in back, but not in the front due to 3" downpipe.
Old Jan 29, 2004 | 04:04 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
oem 21mm front sway
comptech 22mm rear sway
gsr front upper
cusco rear upper
some of you guys take this **** too far.
Old Jan 29, 2004 | 04:11 PM
pdiggitydogg's Avatar
oem si front upper
oem ex front sway
ebay rear upper
ebay rear lower tie
planning oem si rear sway
Old Jan 29, 2004 | 05:49 PM
ATS*Mark's Avatar
OG triple OG
Default Re: how many bars? (Fowler.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fowler. &raquo;</TD></TR><TR><TD CLASS="quote">A.
1997 Cx
CTR 26mm front bar
stock shocks
B.
1997 Cx
stock motor
To me, A was 10x more stable than B. I think sway bars completely make the difference. Strut bars are more show than anything else. I mean, yeah, they offer something, but swaybars are waaaaayyyy more useful.</TD></TR></TABLE>
agreed.
