del sol suspension? pleas help
Old Jan 28, 2004 | 11:22 PM
FATshlong's Avatar
Default del sol suspension? pleas help
ok, i traded an lsd tranny for a 1993 del sol Si, and all i basically need for it is the rear suspension and disk brake assembly. I was wondering if a 90-91 crx si rear disc assembly will fit on to the del sol?
Old Jan 29, 2004 | 01:29 AM
stevecockrill's Avatar
Default Re: del sol suspension? pleas help (badpumpkin)
I doubt it, but could be wrong. The del Sol Si came with rear discs.....are you sure you have an Si model?
Steve
Old Jan 29, 2004 | 03:48 AM
xavior66's Avatar
Dang sounds like you got a good trade there!
Old Jan 29, 2004 | 08:51 AM
FATshlong's Avatar
my buddy had sold the rear disc setup to a kid who wanted to convert drum to disc on his 94 hatch, now i cant find a del sol SI to get the rear disc setup of, so i thought maybe the crx Si disc my work, im probably just goin to take apart my driver side rear end then go try it on the del sol, that probably will give me my answer
Old Jan 29, 2004 | 08:52 AM
foz's Avatar
foz
Default Re: (badpumpkin)
from what I know it doesn't work, you need a 92-00 civic rear end to steal the parts from, I could be wrong, but I'm pretty sure they are different
Old Jan 29, 2004 | 08:56 AM
KiDSoL's Avatar
n/m i didnt read it right.
Old Jan 29, 2004 | 08:57 AM
Slammd Sol's Avatar
92-00 civic si, 94+ teg or any del sol si/vtec
Old Jan 29, 2004 | 09:07 AM
FATshlong's Avatar
cool thanks for the replys
Old Jan 29, 2004 | 09:11 AM
bubbajim's Avatar
it works, ive done it, from a 91 crx si to a 94 del sol, i used the rear trailing arm including all the brake components.
Old Jan 30, 2004 | 09:52 AM
FATshlong's Avatar
if your absolutely positive it will work i think ill go ahead and buy the crx rear disc
Old Jan 30, 2004 | 07:04 PM
salbaje's Avatar
it will work but you will need delsol ebrake cables
Old Jan 30, 2004 | 07:09 PM
Hater's Avatar
nononononononononono.....
Full trailing arm assemblies would need to be from a Sol or 94+ Integra FOR SURE. Any Civic I am not positive about, but the 91 CR-X will not fit.. The dimensions are WAY off..
khallilD
Jun 29, 2008 09:47 PM
yoRt
Mar 26, 2008 07:00 PM
Eg2707
Dec 21, 2006 12:45 PM
delslo93
Jun 29, 2006 04:02 AM
Farrell
Mar 17, 2002 06:21 PM
