camshafts
Old Jan 28, 2004 | 05:51 PM
robert johnson's Avatar
Default camshafts
what are the best cams to put in 2nd gen b16
Old Jan 28, 2004 | 06:07 PM
Sliced Beard's Avatar
Default Re: camshafts (robert johnson)
i usually dont like to say this but search
also this topic is highly opiniated
here is a cut and paste from a previous thread
with a bunch of cam profiles
<U>ALL</U> listed at @ 1mm! &lt;IMG NAME="icon" SRC="https://honda-tech.com/forums/images/smilies/emthup.gif" BORDER="0"&gt;
Integra GS-R
Int-230 dur. / 10.6mm lift
Exh-227 dur. / 9.4mm lift
Civic Si '99 Spec
Int-240 dur. / 10.7mm lift
Integra Type-R Pre '99 Spec
Int-240 dur. / 11.5mm lift
Exh-235 dur. / 10.5mm lift
Civic Type-R And Integra Type-R
Int-243 dur. / 11.5mm lift
Spoon Sports
Int-256 dur. / 11.5mm lift
Exh-245 dur. / 11.1mm lift
Toda Spec A
Int-250 dur. / 11.6mm lift
Exh-240 dur. / 11.2mm lift
Toda Spec B
Int-255 dur. / 12.0mm lift
Exh-245 dur. / 12.0mm lift
Toda Spec C
Int-255 dur. / 12.5mm lift
Exh-255 dur. / 12.5mm lift
Toda Spec D (Estimated)
Int-265 dur. / 12.9mm lift
Exh-275 dur. / 11.9mm lift
Toda VTEC Killer
Int-265 dur. / 12.0mm lift
Exh-255 dur. / 11.5mm lift
JUN Type 1
Int-265 dur. / 10.9mm lift
Exh-268 dur. / 10.0mm lift
JUN Type 2
Int-267 dur. / 12.0mm lift
Exh-265 dur. / 10.9mm lift
JUN Type 3
Exh-265 dur. / 11.5mm lift
Skunk2 Stage 1
Int-252 dur. / 11.6mm lift
Exh-249 dur. / 10.8mm lift
Skunk2 Stage 2
Int-266 dur. / 12.3mm lift
Exh-262 dur. / 11.8mm lift
Skunk2 Stage 3
Int-270 dur. / 12.8mm lift
Exh-279 dur. / 11.8mm lift
Skunk2 Turbo (specs seem low? I called them, the VTEC now has less overlap, great for turbo &lt;IMG NAME="icon" SRC="https://honda-tech.com/forums/images/smilies/emthup.gif" BORDER="0"&gt; )
Int-230 dur. / 9.7mm lift
Exh-225 dur. / 8.9mm lift
Crane Stage 1
Int-243 dur. / 11.6mm lift
Exh-237 dur. / 10.8mm lift
Crane Stage 2
Int-248 dur. / 12.0mm lift
Exh-242 dur. / 11.6mm lift
Crane Stage 3
Int-254 dur. / 12.4mm lift
Exh-248 dur. / 12.0mm lift
Crower 400 (not converted yet)
Int- dur. / 10.7mm lift
Exh- dur. / 9.6mm lift
Crower 401 (not converted yet)
Int- dur. / 11.3mm lift
Exh- dur. / 10.5mm lift
Crower 401T (not converted yet)
Int- dur. / 11.8mm lift
Exh- dur. / 11.3mm lift
Crower 402A
Int-232 dur. / 11.8mm lift
Exh-228 dur. / 11.8mm lift
Crower 402
Int-237 dur. / 11.8mm lift
Crower 403
Int-246 dur. / 12.0mm lift
Exh-238 dur. / 11.8mm lift
Crower 411T
Int-242 dur. / 11.8mm lift
Exh-238 dur. / 11.3mm lift
Crower 412
Int-260 dur. / 11.8mm lift
Exh-252 dur. / 11.8mm lift
Crower 413
Int-269 dur. / 12.0mm lift
Exh-258 dur. / 11.8mm lift
Enjoy! &lt;IMG NAME="icon" SRC="https://honda-tech.com/forums/images/smilies/emthup.gif" BORDER="0"&gt;
Old Jan 28, 2004 | 06:16 PM
Kendall's Avatar
Everything depends upon what you want to do with the engine. If you plan on leaving it stock, then there will be certain options to entertain. If you plan on boost, there will be different options, and if you plan on an all motor build up, the will be even more options to consider. Do some research, set some goals, and then determine how any particular set of cams can help you reach your goals.
rev210k
Jun 30, 2004 12:24 AM
Timmayeg
Apr 25, 2003 11:13 AM
SiREF8
Sep 6, 2002 06:02 PM
00 Si
13
Sep 19, 2001 07:16 AM
