Help: Crashed my car, do i need alignment?
i live in maryland and there is ice and snow all over my neighboorhood.
as i was driving and made a turn, the car slid, and i hit the curb at like 10-15mph.
the right front tire got it. the bumper and lights are ok, there is no appearance that i crashed.
HERES the PROBLEM:
when i drive the car vibrates and i think the right tire wobbles. at 20mph its fine but after that its really bad.
whats going on here? what should i do?
thanks alot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">Check to see if you bent anything. If that doesnt appear to be the problem, yes an allignment would be a good idea.</TD></TR></TABLE>
i already removed the wheel to see and everything seems ok. when i put the wheel back on, it got better. but its still pretty bad. the stock hub is also partially broken.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thrty8street »</TD></TR><TR><TD CLASS="quote">
i already removed the wheel to see and everything seems ok. when i put the wheel back on, it got better. but its still pretty bad. the stock hub is also partially broken.</TD></TR></TABLE>
Could be your problem right there. Get a new hub. Aftermarket wheels that don't have hubcentric rings also have shaking problems.
Could be your problem right there. Get a new hub. Aftermarket wheels that don't have hubcentric rings also have shaking problems.</TD></TR></TABLE>
i meant the hub cap is broken sorry. but yeah i think i will buy a new hub. where can i get one?
You probably need an alignment, but there is a small chance that it's the wheel. Try switching the impacted wheel with the driver's side rear and see if it helps any.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clm »</TD></TR><TR><TD CLASS="quote">You probably need an alignment, but there is a small chance that it's the wheel. Try switching the impacted wheel with the driver's side rear and see if it helps any.</TD></TR></TABLE>
thats a good idea. i will get on that tomarow.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">Haha..don't replace the whole hub before you get an allignment. The allignment place will definately let you know if they can't do it because stuff is bent. </TD></TR></TABLE>
yeah i will go to jiffy lube so they can check my car out. I really hope nothing is bent though.
what could possibley be bent?
yeah you should problably get an alignment done. i went over a curb one time, and one tire was straight, while the other was crooked. Midas couldn't fix it so i ended up going to an alignment specialist. They said something was bent.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coolasice »</TD></TR><TR><TD CLASS="quote">yeah you should problably get an alignment done. i went over a curb one time, and one tire was straight, while the other was crooked. Midas couldn't fix it so i ended up going to an alignment specialist. They said something was bent.</TD></TR></TABLE>
what was bent? how much did it cost you?
every car and accident is different my friend.............dont look to investigate other peoples cost and damages until you definately find out what the problem is because u might end up replacing parts that are still good and might end up losing more money in the long run.........so to end my rambling i would suggest u wait until someone who knows more about cars than u takes a look, not saying that u dont know anything but u sound a little unfamiliar with what to look for....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red CiViC Hatch »</TD></TR><TR><TD CLASS="quote">every car and accident is different my friend.............dont look to investigate other peoples cost and damages until you definately find out what the problem is because u might end up replacing parts that are still good and might end up losing more money in the long run.........so to end my rambling i would suggest u wait until someone who knows more about cars than u takes a look, not saying that u dont know anything but u sound a little unfamiliar with what to look for....</TD></TR></TABLE>
i know im just tryin to get more familiar with the subject and trying to get a broad idea of what to expect.
