automatic ECU
Old Jan 28, 2004 | 04:36 PM
Styler93GSX's Avatar
Default automatic ECU
I did a minime swap on a 91civic DX and I got an automatic ECU with the swap do I need a different ecu for my car to run. Thanks. BTW my car is a 5 speed
Old Jan 28, 2004 | 06:26 PM
blah13's Avatar
Default Re: automatic ECU (Styler93GSX)
you can run it with the auto ecu, it'll throw a code for "lock solenoid" or something like that....but it will run.
Old Jan 28, 2004 | 08:47 PM
Donkey85's Avatar
Default Re: automatic ECU (blah13)
i dont know if that 100% true, i have a 4speed std and i wanted to put a pm5 in it instead of the shitty pm9 later to find out it was from an auto it flashed the lock up slanoid and would not start
Old Jan 28, 2004 | 08:53 PM
Targa250R's Avatar
be professional
It will run, but it will run like ****. At least, that's the way it is with '92+ Civics . . .
If you need to use the car, the auto ECU is fine, but in the meanwhile look for a manual ECU.
Old Jan 28, 2004 | 09:15 PM
JonGP4's Avatar
Default Re: automatic ECU (Targa250R)
it runs fine, just thows a CEL.. ran with one for a couple weeks
Old Jan 29, 2004 | 05:25 AM
91civicDXdude's Avatar
^^^^yep.. i ran an auto PG7 with my d16z6 for almost a year, just throws a check engine light all the time, but runs fine
Old Jan 29, 2004 | 09:10 AM
4drEF's Avatar
Keyboard Humorist
Well, I think it depends WHICH auto ECU you got. It will run on an Integra auto and you will have a check engine light. It will NOT run on a 88~91 Dx/Lx auto ECU.
Why?
The ECU only supports 2 injectors. Your mini-me swap now includes 4 injectors.
Old Jan 29, 2004 | 10:37 AM
90hbvtec's Avatar
Default Re: (91civicDXdude)
yo 91civicDXdude when it threw a CEL were u flashing any codes?...cause i got a b16a with a pr3 ecu..there is no code flashing but my CEL is on..is that why?...having a auto ecu?..
Old Feb 2, 2004 | 12:34 PM
Default Re: (90hbvtec)
Ok I have a a sohc vtec swap with the ECU that came out of the Delsol. The Delsol was an automatic. So I'm not sure I think my 91 is OBD0 and teh delsol is obd1. Oh well we'll find out.
Old Feb 2, 2004 | 03:28 PM
acy76's Avatar
Default Re: (Styler93GSX)
get in touch with me ASAP
Baller111
May 6, 2012 10:02 AM
max_man4945
May 21, 2010 09:26 PM
EGandDArida
11
Oct 1, 2008 07:49 AM
wronghand
Jun 6, 2002 04:53 PM
