Installing a turbo on 100,000 mile engine
Old Jan 28, 2004 | 03:02 PM
elderjoe's Avatar
Default Installing a turbo on 100,000 mile engine
Is installing a turbo on an engine with 100,000 miles a smart idea or not? Would i be safe doing so?? Any tips, comments, etc, please!by the way, its a 92 accord with an f22
Old Jan 28, 2004 | 03:10 PM
cbstd's Avatar
Default Re: Installing a turbo on 100,000 mile engine (elderjoe)
I am not a fan of turbos and homemade turbos are way down at the bottom of my list, so consider this when I give my opinion.
A turbo will put more strain on every system inside your engine and a 100k mile engine is NOT a good place to start. But, if you keep the boost to a fairly low number (about 5psi) your engine will be able to survive... for a while.
Instead of slapping a turbo on a tired engine, why not refresh what you have with a port and polish, more agressive cam and a bigger throttlebody? The car will have a lot more power, be more driveable and reliable.
Scott
Old Jan 28, 2004 | 03:12 PM
jwogen1's Avatar
Default Re: Installing a turbo on 100,000 mile engine (cbstd)
i have to agree, the turbo will eventually blow your engine and then you are pretty much back at the beginning of what to do next---new car, engine swap etc......
Old Jan 28, 2004 | 03:15 PM
Accord94DX's Avatar
Default Re: Installing a turbo on 100,000 mile engine (jwogen1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwogen1 &raquo;</TD></TR><TR><TD CLASS="quote">i have to agree, the turbo will eventually blow your engine and then you are pretty much back at the beginning of what to do next---new car, engine swap etc......</TD></TR></TABLE>
nonsense!
compression test and leakdown. when you pull the valve cover, how does the head look? Caked with old burned oil or still ok?
I have seen a bunch of 100k+ motors in at honda that looked brand new underneath because the owners care for the cars and CHANGE THIER F&#R*YD oil!!
Old Jan 28, 2004 | 03:35 PM
ForceThis!'s Avatar
Default Re: Installing a turbo on 100,000 mile engine (Accord94DX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Accord94DX &raquo;</TD></TR><TR><TD CLASS="quote">
because the owners care for the cars and CHANGE THIER F&#R*YD oil!!</TD></TR></TABLE>
Old Jan 28, 2004 | 05:05 PM
LookingForVTEC's Avatar
I have seen plenty of Hondas with 100k + mi add turbo kits to them with out problems. I agree with "Accord94DX" I would do a compression and leak down test to determine what kind of condition the engine is in before boosting. If the engine is in pretty good condition I would do a pretty thorough tune-up making sure that the motor is running like it should. Besides that I say go for it. Oh yea don’t forget to change the timing belt if you haven’t yet!
Old Jan 28, 2004 | 05:41 PM
accordfreak's Avatar
Default Re: Installing a turbo on 100,000 mile engine (ForceThis!)
i boosted at 90k about 8psi daily .. now at 103k i'm boosting 14psi no problem
dinku27
Sep 15, 2005 01:34 PM
lude1888
Aug 23, 2005 07:47 PM
skunkwhat
May 22, 2005 05:41 PM
